Tire Pressure Question - 265/75R15
Discussion in '1st Gen. Tacomas (1995-2004)' started by mac84, Feb 28, 2018.
  1. Feb 28, 2018 at 8:29 AM
    mac84
    mac84 [OP] Well-Known Member
    Alabama
    2015 Tacoma TRD Sport 4WD MGM
    Firestone Destination LE2's on my 2000 Tacoma I bought last year. Still trying to dial in the tire pressure as I've recently replaced the suspension all the way around and the tie rod ends (inner and outer) as well as a few other things. What are you guys running your tires at? It's just me in the drivers seat most of the time.
    I noted that the door panel sticker only has the smaller tires - Mine's a PreRunner and looks like came stock w/ the larger tires (according to my owners manual).
    Thanks!
  2. Feb 28, 2018 at 8:33 AM
    NCJeyota
    NCJeyota Well-Known Member
    Raleigh,NC
    2013 acces cab TRD offroad M/T 4wd
    35 psi
  3. Feb 28, 2018 at 8:34 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I've run 32 - 40 depending on the tire.
    somewhere in the mid 30's is usually the sweet spot. could also try the chalk test and see the pattern and contact patch
  4. Feb 28, 2018 at 8:34 AM
    eon_blue
    Azusa, CA
    I have the same size tires but KO2s and I run them at 35 psi on the street.
  5. Feb 28, 2018 at 8:36 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    29psi no load 35psi loaded (anything over 200lbs in the bed)
  6. Feb 28, 2018 at 8:55 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    My '01 door placard says 26psi all around, but in my opinion that is a "suggestion" pertaining to the OEM tires and to give a better ride/handling mix. My rule of thumb is to go right between the door placard psi and the max psi stated on your current tire's sidewall. On mine, placard says 26psi, sidewall says 35psi max, so I run my tires 31psi.
  7. Feb 28, 2018 at 9:02 AM
    mac84
    Alabama
    Thanks guys....I have been at 29 all around w/ no load. I had some cupping on the fronts and I've rotated them to the back after my suspension work. I took it the Firestone for front end alignment yesterday and I need to check to see if they've modified the pressure. Last time I got them to rotate and balance they put them at 40!
  8. Feb 28, 2018 at 10:40 AM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    I run 31 in my KO2’s
  9. Feb 28, 2018 at 11:25 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    I ran 40psi in my Firestone Destination A/T (265/70-16, same size as yours) and had very good tread wear. I still have them mounted on my rims in storage. got ~50k+ on them with probably another 5K+ to go still.
    They were a little stiffer but hey, it's a truck. the worn suspension helped :D
  10. Feb 28, 2018 at 12:00 PM
    mac84
    Alabama
    Thanks Frizz...I'm also dialing in for comfort. I'll bump them up a bit from the 29 and see what it feels like. I realize it's a truck but I've reached a time in my life where comfort is enjoyable. HA!
    mechanicjon likes this.
  11. Feb 28, 2018 at 1:03 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    I hear ya. I keep my S/T Maxx around 33. the suspension upgrade makes it stiffer but I've gotten used to most of it now.
  12. Feb 28, 2018 at 3:50 PM
    Aught2TaCO
    Aught2TaCO Well-Known Member
    Troy
    Wheat Ridge, CO
    '02 Taco TRD, aka Pearly
    Billie 5100's, new leafs, Falken WILDPEAK A/T 3W, 265/75/16E
    Frizzman mentioned the chalk test, here's a vid showing how to adjust tire pressure...
