Tire Pressure Recco. Load E Toyo AT3’s
Discussion in '3rd Gen. Tacomas (2016-2023)' started by baltimorebirds2, Oct 22, 2022.
  1. Oct 22, 2022 at 7:47 PM
    baltimorebirds2
    baltimorebirds2 [OP] tacomama
    Brooks
    Maryland, United States
    2018 MGM Tacoma TRD Sport DCSB 4x4
    TRD Pro 17” Wheels, Toyo Open Country AT3 33s” (255/80/R17), Hooke Road Offroad Roof Rack, LEDs (Low Beams, High Beams, Fog Lights, Interior Lights, Reverse Lights, License Plate Lights), Diode Dynamics SS3 Sport Fog Lights (Yellow), Sequential Turn Signals, OME Nitrocharger Plus, OME 4004's & HS 0.5 Spacer for 3" Lift, JBA UCA, Icon RXT Option 2 Leaf Springs 2.25" Lift, Yukon Clamshell Bushing, Alpine ILX W-650 Stereo, Infinity Primus 6004a Amplifier (140w*2), Sound Ordnance M75-4 Amplifier (75w*4), Infinity Kappa 693C Component 6x9 Speakers, Infinity Kappa 63XF 6.5 Speakers, TRD Shift Knob, Black Emblem Overlays, TRD Grille Badge, OEM Door Sill Protectors, Driver’s Seat Jackers, Pop and Lock Power Tailgate Lock, AJT Designs start button and trim, 4x4 knob, shifter trim, and cupholder trim, MESO Customs Vent Rings and Door Handle Covers, Gasshole, Drop Stops, AC Drain Mod, Bed Lights, Rough Country Roll Up Tonneau Cover, Window Tint, KDMAX Tune
    Hey all,
    Been doing some reading and have heard people saying that like 34-35 psi is a bit too low for a load E tire. On my rig, I have LT 255/80/R17 Toyo AT3’s in load range E. People are saying to go up to 40 something and some say 30s is fine. Most of the time the truck isn’t loaded, and I rarely ever tow anything and if I did it would be a few times a year at the most. Any tire pressure recommendations for guys running either these exact same tires or similar tires? I’m just trying to find a good pressure for the type of use the tires are getting. I want them to wear as good as possible as well. Any help is appreciated. Thanks.
  2. Oct 22, 2022 at 7:50 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I'm running 315/75/16s and my warm tire pressure is 35 psi
  3. Oct 22, 2022 at 7:55 PM
    baltimorebirds2
    Brooks
    Thanks for the input. I feel like lower pressures are fine if you’re not loading it up or towing?
  4. Oct 22, 2022 at 8:01 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    I run 38psi in my 265/70r17 Toyo RT E if I’m doing a highway trip or towing the rv, otherwise I keep it around 32psi for daily driving.
    Tire wear is even over 3 years, so far so good.
    baltimorebirds2[OP] likes this.
  5. Oct 23, 2022 at 1:47 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    E rated is a lot. I run 30 cold in my Toyo AT2s and they are still looking great. I have about 20k miles on the tires and I'm switching them to my 99 4Runner and going to the new AT3s and might have to get the E rated 275/70/17s and I was asking myself the same question, air pressure? I think 32 cold and let them warm up to 35.
    shotgunbilly420 likes this.
  6. Oct 23, 2022 at 9:08 AM
    TSAVO
    TSAVO Well-Known Member
    Tempe, AZ
    2018 TRD OR
    285/65-18 Nitto Terra Grappler G2 E loads. I run 40 psi and ride quality is still just fine. Been running these for about 5 years and 70K miles with no issues.
