Tire pressure sensor and changing wheels
Discussion in 'Wheels & Tires' started by TacomaTim, Aug 29, 2009.
  1. Aug 29, 2009 at 3:58 PM
    TacomaTim
    TacomaTim [OP] Well-Known Member
    Tim
    Meadville, PA
    2015 TRD Pro Tacoma
    I'm sure this is redundant but I haven't found the answer yet...I have an '08 Tacoma and want to put new wheels and tires on. Can I easily remove my stock wheels and just put on new ones or is there going to be a problem with the pressure sensor? I don't know if the sensor is on the wheel or on the brake.
    Many thanks!
  2. Aug 29, 2009 at 4:38 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Do you have alloy or steel rims?
    Are you keeping your stock set of rims and tires?
    The sensors are screwed into each wheel for 06+ tacomas.
    The alloy and steel wheel sensors are different.
    The alloy wheel sensors are reported to swap more easily to aftermarket applications than the steel.
    The steel wheel sensors are reported to swap to some aftermarket rim applications if turned a 180 degrees when having new tires mount.
  3. Aug 29, 2009 at 8:27 PM
    TacomaTim
    Tim
    Meadville, PA
    2015 TRD Pro Tacoma
    Thanks for the quick reply. Very helpful.
    My wheels are alloy and I plan to keep them so mabe it will be easy. Tomorrow I'm going to put some 275 x 17s on from a tundra and see how it works. Haven't lifted it yet, so I'm guessing they'll be too big.
    Thanks again.
  4. Aug 29, 2009 at 11:00 PM
    cjimenRR
    cjimenRR Be Good or Be Good At It
    North Hollywood, Ca
    12' Sport DC,LB, 4x4
    Make sure you let all the air out first, then unscrew the sensor so it falls in the tire before you try and break the bead seating
  5. Aug 31, 2009 at 6:18 AM
    TacomaTim
    Tim
    Meadville, PA
    2015 TRD Pro Tacoma
    Thanks for the tip, I'll do that.
  6. Sep 3, 2009 at 3:06 PM
    GABoy
    GABoy Active Member
    Mark
    Acworth, GA
    2008, Double Cab, PreRunner, SR5
    Yakima Load Warrior, Yakima Kayak stackers, Kenwood's DPX301 CD/XM/MP3/HD (Double-Din Player), Kenwood KCA-iP500 iPod Control Interface, Kenwood XM Radio Tuner, Garmin C330 GPS, Kobalt toolbox, BBS 20 inch Rims off a Toyota Tundra
    How much do 4 sensors cost to replace? OEM and Aftermarket?
  7. Sep 3, 2009 at 8:06 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    I paid $85(each) online, stealership was $130 , oem sensors
  8. Sep 3, 2009 at 10:45 PM
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    Ouch! I hate these darn sensors!
  9. Sep 4, 2009 at 8:36 AM
    PR45
    PR45 Well-Known Member
    Los Angeles
    PreRunner SR5 4cyl
  10. Sep 4, 2009 at 4:02 PM
    Tacoyota
    08 4wd
    i forgot , i saw aftermarket for $57 when i bought oem @ $85
