tire pressure sensor (spare?)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by little red, Oct 8, 2011.
  1. Oct 8, 2011 at 3:02 AM
    little red
    little red [OP] Well-Known Member
    Central GA
    PreRunner SR5
    I have been told my 2006 tacoma has the 5 tire monitor system that monitors all four tires on the truck as well as the spare. My question is how does this system work. I don't see any wires going to the spare tire area. (I know the tires are not plugged into any wires but something has to relay the pressure from the sensor in the wheel to the warning light)
  2. Oct 8, 2011 at 4:20 AM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    it operates wirelessly by radio frequency (RF)
  3. Oct 8, 2011 at 4:21 AM
    Hook & Ladder
    Hook & Ladder Well-Known Member
    Maine
    16' TRD Tacoma
    The project @c4_fabrication-Sliders, HC bumper w/ swing out @kb_voodoo_fabrications-Bed rack @tepuitents-RTT @cali_raised_led-Fogs, ditch lights, bed stiffeners @prinsudesign-Roof rack @kingshocks-2.5 with adjuster @totalchaosfabrication-UCA @rcioffroad-diff skid plate Follow at @wicked_overland #nacrew
    most places will inform you if them and ask if you want to keep them or add them in your next set of tires/rims.
  4. Oct 8, 2011 at 4:56 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    From the FSM
    The 06s did have them in the spare. I ended dropping my spare & flipping it over to make check tire pressure easier. It will trigger the light on occasion.
    The system takes up to a max 5 codes. The sensors have id numbers that get registered in the system. The docs explain that.
  5. Oct 8, 2011 at 9:50 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    the wires are invisible.
  6. Oct 8, 2011 at 9:59 AM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
    I didnt even know we had this!
  7. Oct 9, 2011 at 3:28 AM
    little red
    Central GA
    PreRunner SR5
    I'm glad you told me that because I was tempted to turn mine over to make it easier to check and fill. I don't want the light to keep coming on so I may go to plan B. They make extensions that can be hooked up to the valve stem and dropped down through the wheel so you can get to it. (I have seen them on trucks with dual rear wheels to you can get to the inside tire)
  8. Aug 14, 2012 at 8:05 PM
    FTL911
    FTL911 Well-Known Member
    Paul
    SoCal
    06 PreDblCabTRDSport
    You guys are great!!!
    I am running all around checking all my tires and figuring I have a faulty sensor in one of my tires, since my dash sensor is illuminated. I never stopped to think about the spare. Thanks for solving my problem, fellas.
  9. Aug 14, 2012 at 8:32 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    From what i understand the tpms sensors have batteries that need replacement after around 7 years. Anyone had theirs replaced yet and how much did it cost?
  10. Aug 14, 2012 at 9:10 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Sensors are anywhere from $75 to $200 each depending on where you buy them.
    Batteries are not technically replaceable.
    It can be done, but not with OTC batteries.
    Buy 5 new sensors, write down the serial numbers, have them installed, inflate the tires, and someone with a techstream will need to register the new serial numbers with your ECU.
    You can thank our nanny government and Ford's erroneous inflation recommendations on a SUV tire for this. This Federal requirement is a direct result of the Explorer/Firestone tire failure issue.
  11. Aug 14, 2012 at 9:18 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    jeez rich, that sucks! i didnt know they were so expensive. didnt know it was a direct result of the ford/firestone thing either. another reason to make fun of my friends i guess. gotta love ammunition.
    i've heard rumors of a dissableing code that can be done to get rid of that light. is this true?
    i really dont mind the system too much though, as long as it works. . . .i dreaded it when i bought it, but then again im prone to hating anything government mandated
  12. Aug 15, 2012 at 8:31 AM
    OffroadToy
    About the time the batteries/sensors need replacement is when i'll be putting something over the dash to cover the light. I refuse to spend that kind of money on something i can easily do with a $5 tire gauge.
  13. Aug 15, 2012 at 3:10 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    wonderful news about the non-serviceable-proprietary batteries. :rolleyes:
  14. Aug 15, 2012 at 5:46 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    The batteries aren't proprietary... they are basically standard CR3023 type lithium cell with solder-tabs welded on.
    They are available, just not from Walgreens.
    The units can be taken apart and the batteries replaced, but there is the risk of damaging the unit during disassembly.
  15. Aug 15, 2012 at 8:21 PM
    Fury
    Fury Well-Known Member
    Hi all.
    The spare was dropped from the TPWS on the 2009 MY.
    To access the spare's valve, drop it down a bit and rotate the spare so the valve faces straight back (then lift it back up). The valve can then be easily reached to both check the pressure and fill if necessary, without flipping the spare to the incorrect position.
    Cheers
    Ray.
  16. Aug 15, 2012 at 8:24 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    . Sub'd
  17. Aug 15, 2012 at 8:30 PM
    zackn291
    zackn291 Well-Known Member
    Zack
    Princeton, Ontario
    '05 Taco TRD
    Bilstein 5100 set at 2.5", 2" AAL, Fog light mod.
    I work at Chrysler and deal with TPMS all the time. One thing alot of people do is they say "I just checked my tire pressure, inflated the tires and the light is still on". Well if you inflate the tires too much it will set a code and the TPMS light will come on. Make sure you look at the door sticker and go by what it recommends and USE A GAUGE. Just my 2 cents as a tech dealing with it all the time lol
  18. Aug 15, 2012 at 8:35 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    From the owner's manual:
    When the light comes on: Low tire inflation pressure.
    When the light stays on after blinking for 1 minute: Malfunction in the tire pressure warning system.
  19. Aug 15, 2012 at 10:13 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Thank you for elaborating on this. Personally, I'd take a stab at repairing them should the need ever arise.
  20. Aug 16, 2012 at 5:36 AM
    geoff7877
    geoff7877 Well-Known Member
    Petaluma, CA
    2018 TRD Off Road 4X4 Double Cab
    So, I've heard that the TPMS sensors can be reset to read at a lower PSI by holding down a button located under the steering column. My steelie sensors didn't fit my new wheels. Can I reset the with "0" PSI and get rid the light? Just a thought.
    Sorry for the side track. ;)
