Tire Pressure Sensor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by saltus25, Jan 5, 2013.
  1. Jan 5, 2013 at 8:01 AM
    saltus25
    saltus25 [OP] Well-Known Member
    Graydon
    Angleton,TX
    Flowmaster American Thunder Exhaust, K&N intake, OME 3" lift, Pro Comp Extreme MT2 tires, Mickey Thompson Classic II Wheels, Spidertrax 1.25" wheel spacers, URD short throw shifter, KC 100 watt lights, custom steel mesh grill, halo headlights, Rigid Industries Dully's, SOS Offroad Concepts front bumper, SOS Offroad Concepts custom rear bumper, All Pro and BAMF skids
    Does anyone know how to bypass the tire pressure sensor to make the light go off? My new wheels wouldnt allow the stock sensors to be put back in.
  2. Jan 5, 2013 at 8:05 AM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    tape.....
    somebody somewhere once suggested building a small tube that could be pressurized, and tossing said tube under the seat
  3. Jan 5, 2013 at 8:05 AM
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
  4. Jan 5, 2013 at 8:06 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
  5. Jan 5, 2013 at 8:12 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    One option is a canister made out of PVC with a valve stem on one end. Just throw the sensors in, close it up, fill it to around 30psi and stash it in a storage area or underneth the truck.
  6. Jan 5, 2013 at 10:43 AM
    seric007
    seric007 Well-Known Member
    just remove the stupid led from the cluster. easy to do.
  7. Jan 6, 2013 at 1:06 PM
    saltus25
    Graydon
    Angleton,TX
    thanks for the input. ill see what i can figure out
