Tire pressure sensor?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Fred Pabst, Nov 9, 2015.
  1. Jan 16, 2016 at 2:34 PM
    muddytacos
    muddytacos Now own '16 F150 - 16 Taco drove me to Ford
    lost in the swamp
    2016 Ford F150 2.7L Ecobooooooost
    I believe I have v10.10.018 and the FCC ID is PAXPMVC015
  2. Jan 16, 2016 at 2:41 PM
    muddytacos
    lost in the swamp
    I went from steel to AL wheels. I don't believe there is that button on the 2016 but I remember it on my 2011. I'll have to RTFM.
  3. Jan 16, 2016 at 2:48 PM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    There IS that button on the 16's. I drove about 45 miles on the interstate at 70 mph after my wheel swap, and my sensors never picked up the pressures on the corners. Whatever the dealer did with the ECU brought back the corner pressures.
    G.
  4. Jan 16, 2016 at 3:38 PM
    muddytacos
    lost in the swamp
    Found it! I followed the earlier instructions on using the reset button but the light stays solid yellow. Currently throwing C2126 code. It will let me set tire positions and writes that to the ECU, but it will not write the sensor IDs.
  5. Jan 16, 2016 at 3:43 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  6. Jan 16, 2016 at 4:21 PM
    mvusa
    mvusa Well-Known Member
    2016 Silver Tacoma TRD Off Road 4x4 Access Cab V6 Auto
    I believe you will need Toyota Techstream v10.30.029 for 2016 Tacoma vehicle coverage.
  7. Jan 16, 2016 at 4:53 PM
    juliopapa
    juliopapa Well-Known Member
    2016 TRD Sport DBL cab Inferno
    If I have a different set of wheels with winter tire, no TPMS, does it disable anything... besides not sending the pressure info?
  8. Jan 16, 2016 at 5:00 PM
    muddytacos
    lost in the swamp
    Thanks tomwil, I just got that installed on my DT.
    mvusa, I'll try that next if 10.20.030 fails to write the sensor IDs. Thank you!
  9. Jan 16, 2016 at 6:34 PM
    unixadm
    unixadm Well-Known Member
    Super White 2015 DCSB 4x4 Off Road
  10. Jan 17, 2016 at 6:02 PM
    J-Rock
    J-Rock Well-Known Member
    2016 MGM TRD OR
    I tried to download on that link but I get an error page when I click the version number that looks like this:
    This XML file does not appear to have any style information associated with it. The document tree is shown below.
    <Error>
    <Code>NoSuchKey</Code>
    <Message>The specified key does not exist.</Message>
    <Key>techdoc3/GTS OTHER PC/GTS_10.20.030_TME_NDSI.exe</Key>
    <RequestId>E4A74F781317B941</RequestId>
    <HostId>
    xZtblqHZtfoW/cnC7AjSp0kLu33mG5nFTr3o9pJFq0kDuZqij+XpTgG9/T3q5NU1PFEzcZY0rBw=
    </HostId>
    </Error>
    are others able to download the software from that link or is the site broken right now? I tried it without logging on and got that error and then tried again after registering and got the error again.
  11. Jan 17, 2016 at 6:31 PM
    muddytacos
    lost in the swamp
    Right click link, select "save as"
    tomwil likes this.
  12. Jan 19, 2016 at 2:10 PM
    muddytacos
    lost in the swamp
    No version of TS would update my sensor IDs. Tires Plus did it with their Snap-On unit when we told the handheld it was a 2015 Camry.
    My TPS is now 100% functional...
  13. Jan 19, 2016 at 4:58 PM
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
    Thanks for letting us know, but surprising!
    Wonder what version the dealerships are using?
  14. Jan 22, 2017 at 11:54 AM
    Roursca
    Roursca New Member
    I HAVE THE SAME PROBLEM AND USE TECHSTREAM 11.30 ¿ HOW DO YOU SOLVED?
  15. Jan 22, 2017 at 12:31 PM
    #35
    sqa4life
    sqa4life Well-Known Member
    2017 SR5 4x4 DCLB MGM
    What are the disadvantages other than the tire pressure warning light comes on if I don't put any TPMS sensors on the tires/wheels?
    I just bought a set of wheels/tires from the Tacoma limited (18" with Michelin tires) and planning to have discount tires swap the sensors to this new set. Then keep the current set of wheels/tires (without sensors) as backup or winter.
    Thanks
  16. Jan 22, 2017 at 12:38 PM
    #36
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Don't waste your time, money or effort...! Use a 3/4" round piece of black electric tape and cover that dumb-ass light..! Problem solved for less than 1 cent..!
    sqa4life[QUOTED] likes this.
