Tire Pressure Sensor..
Discussion in 'Wheels & Tires' started by ninorth, Oct 28, 2009.
  1. Oct 28, 2009 at 9:04 AM
    ninorth
    ninorth [OP] T-REX
    Nick
    Yucca Valley, CA
    06 Access cab 4x4 off-road
    What happens if you mix up which sensor was on which tire? Does it matter? can a RF be on a RB? or a RF be on a LR? And if it matters how can I tell which goes where?
  2. Oct 28, 2009 at 9:07 AM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
  3. Oct 28, 2009 at 9:12 AM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    Hmm I don't think so. I've thrown all of my sensors in a pressurised tube, which I keep in the truck. No light has lit up yet and it's'been about 8 months now.
  4. Oct 28, 2009 at 9:12 AM
    ninorth
    ninorth [OP] T-REX
    Nick
    Yucca Valley, CA
    So what do I do now since they are mixed up?
  5. Oct 28, 2009 at 9:32 AM
    NetMonkey
    Geogetown, TX
    hmm... thats true.
    at least for programming the system, it knows which sensor goes to which tire. maybe after its programmed it doesnt matter?
  6. Oct 28, 2009 at 9:36 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    no, i think the car's brain just reads 5 sensors in it proximity.
  7. Oct 28, 2009 at 9:51 AM
    Warped
    Warped N4LJ
    Jim
    Eastern Ky
    2024 Tacoma TRD Off Road
    If the vehicle has a TPMS that indicates 'which' tire is low, it matters.
    If the vehicle has a TPMS that only indicates that 'A' tire is low it doesn't matter.
    If you have mixed up the sensors on a TPMS system that can alert you "which" tire is low.
    You would need to have the dealer reprogram the sensors to the TPMS system.
    Or you could let the air out of the tires one at a time to determine where the TPMS thinks that wheel belongs.
  8. Oct 28, 2009 at 9:54 AM
    FuTang909Inamo
    FuTang909Inamo Well-Known Member
    Socal IE
    03 TRD PreRunner
    Deckplate mod, Trueflow drop in filter, clear corners, 31 BFG A/T on 15x8 Mb Razors.
    Don't think so either...it would be hell to rotate tires. You'd have to mount and dismount the tires if the TPMS were wheel or corner specific, if that was the case. Plus i'm sure shops don't label the wheels when they're putting on new tires. They just throw that shit on and go.
  9. Oct 28, 2009 at 10:01 AM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    It does not matter, at least in my case. I just rotated my tires and no problem with the sensor. When my spare was low it just indicated a problem. Did not tell me which tire was low. Had to check them all until I found the tire with low pressure.
  10. Oct 28, 2009 at 10:09 AM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    FTW, it doesnt matter. Discount tire broke two of my sensors and replaced them and moved tires and sensors around WITHOUT resetting any part of the system. It just makes sure all 5 sensors are in existence and working properly
