Tire pressure sensor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dakotariver, Nov 22, 2021.
  1. Nov 22, 2021 at 2:37 PM
    Dakotariver
    Dakotariver [OP] New Member
    2011 Tacoma TRD sport
    Bought the truck with aftermarket rims and tires. 5 years later getting new tires on and the guy at the shop is saying he can't take them off without breaking the sensor?? Anyone had this issue
  2. Nov 22, 2021 at 2:40 PM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Take it to a new tire shop. A shop that actually knows what they're doing.
    blu92in99 likes this.
  3. Nov 22, 2021 at 2:42 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    How does he know it even has sensors?
  4. Nov 22, 2021 at 3:17 PM
    clenkeit
    Colin
    Lakewood, CA
    TPMS sensors look different from a regular valve stem - even from the outside of the wheel. It's pretty obvious if you look at two side by side. Usually regular valve stems are rubber and the TPMS ones are metal.
  5. Nov 22, 2021 at 7:07 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Can you post a close up picture of your rims.
    TnShooter likes this.
  6. Nov 22, 2021 at 8:05 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I'd buy new sensors and have them installed with the new tires. Typical life of sensors is 7-8 years and the ones you have now won't outlast the new tires. If you wait until they die you'll have to pay to have new ones installed, or wait until you buy tires the next time. A set of 4 new sensors now will cost you about $80 and any shop will install them free when mounting new tires. Expect to pay $10-$20 per tire to have them installed later.
    Depends on the vehicle. The ones on many other vehicles are rubber and look exactly the same as old school stems with no sensors.
  7. Nov 22, 2021 at 8:11 PM
    Bishop84
    Bishop84 Well-Known Member
    So what can happen is the valve core can corrode into the TPMS and you can't remove it. Sometimes they are over torque as well to compound the issue.
    Metal valve caps can also fuse to the metal housing.
    b_r_o, 2015WhiteOR and Dm93 like this.
  8. Nov 25, 2021 at 5:02 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Rubber or metal stem check your pressure like we have done for decades. Electrical gauge in my glove box it's not hard and maybe you'll have a look at the tire ware while you are at it..
    OffroadToy likes this.
  9. Nov 25, 2021 at 5:11 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Just get rid of the &%$#*! sensors and buy a tire pressure gauge.
