Tire Pressure sensors
Discussion in 'Wheels & Tires' started by morphiend, Jun 30, 2010.
  1. Jun 30, 2010 at 1:41 PM
    morphiend
    morphiend [OP] Member
    One of my tires has a slow leak in it. I was thinking of using the green Slime to see if it will fix it. (worked well for me on a different truck) I was wondering if the green Slime would interfer with the tire pressure sensors?
  2. Jun 30, 2010 at 1:43 PM
    sobos_tacoma
    sobos_tacoma Member
    jacksonville, north carolina
    06 double cab v6 4x4
    dick cepek dc1 rims and fcII tires
    i have been told that it would. i have not tried myself through.
  3. Jun 30, 2010 at 2:00 PM
    morphiend
    thanks Phantom
    I didn't know about any of that fix-a-flat stuff, though I've never used that stuff. I've only ever you used the "Slime" which just seals small leaks, but does not re-inflate. You make an excellent point about the mess to clean up though.
  4. Jun 30, 2010 at 2:01 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    dont do it fix it right.....
  5. Nov 21, 2010 at 6:17 AM
    Tommo
    Tommo Well-Known Member
    Fairfax, VA
    base 4X4
    +1 brutalguyracing, plug it!
  6. Nov 21, 2010 at 8:01 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    x2. Tire shops hate that crap too. I used it in dirt bike an ATV tires and dreaded changing the tires, that stuff gets everywhere. Do the soapy water check to find out where it's leaking and use a tire plug or replace the gasket on the TMPS sensor depending on where it's leaking.
  7. Nov 21, 2010 at 8:16 AM
    Jimmyjohn
    Jimmyjohn Well-Known Member
    Jim
    Big Sky Country Montana
    06 SR5 4x4 DLB CAB
    Smitty Blt Bull Bar& Skid Plate, PIAA 525SMR lights
    I use Slime in my atv tires and the shop hates me
