Tire pressure sensors?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jimrb71, Apr 16, 2017.
  1. Apr 16, 2017 at 6:28 PM
    Jimrb71
    Jimrb71 [OP] New Member
    Jimmy
    Hello. I have a brand new 2017 Tacoma SR w/the stock steel wheels. I will be purchasing a set of 2017 upgraded factory alloys to replace the steel wheels. What needs to be done to make the pressure monitoring system right? Thanks!
  2. Apr 16, 2017 at 6:30 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Welcome to TW
    Who doing the install? If a shop they will transfer them and reprogram.
  3. Apr 16, 2017 at 6:34 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    If I am not mistaken, I do not think the TPMS Sensors from Steel Wheels are compatible with Aluminum Wheels.
  4. Apr 16, 2017 at 6:40 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    ding ding ding ding ding
    we have a wiener
    lol
    yep steel TPMS won't work for alloy wheels. I just bought a set from toyota for my new wheels and ya they needed to know if it was alloy or steel as they are two different sensors.
    shakerhood[QUOTED] likes this.
  5. Apr 16, 2017 at 6:42 PM
    BigEasy
    BigEasy Well-Known Member
    Rob
    PNW
    2020 Tacoma TRD/OR DCLB
    Nada
    You are correct, and vice versa
  6. Apr 16, 2017 at 7:49 PM
    Jimrb71
    Jimmy
    OK. Thank y'all. So I'll need to purchase the sensors. From Toyota? Do they need to be programmed to the truck? I was going to have tire shop swap the wheels /tires.
  7. Apr 16, 2017 at 7:53 PM
    marinetaco
    marinetaco Well-Known Member
    Bobby
    2005 Tacoma TRD
    The sensors will work. You just need to rotate the sensor 180 degrees. Just have to be aware of that when you have the tires replaced or a flat repaired.
  8. Apr 16, 2017 at 8:06 PM
    BigEasy
    Rob
    PNW
    Nada
    Mobiletron TPMS TX-S010 For Lexus/Scion/Subaru/Toyota 42607-30060, SU003-00754, 28103-CA000, 42607-06020, 42607-in 315MHz Tire Press https://www.amazon.com/dp/B01N34RR7C/ref=cm_sw_r_other_apap_UJbXvU1hK3cBq
  9. Apr 17, 2017 at 5:22 AM
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    You can either chance it with the factory steel sensors by flipping them 180 as mentioned above (they can break if you have a flat, or if not careful on install).
    Or, order four of these and steal the plastic caps from your original sensor stems to mount them. Many dealers will try to price gouge you a few hundy$ to reprogram the ECU, but $75 is the most reasonable I found after calling around.
    When I upgraded my wheels, it was extremely difficult to find a shop who knew how to work with configurable aftermarket sensors. Those can work, too ... but understand that it's going to take work finding a shop who can install them properly. It might be worth a call, as it's been 4 mos since I swapped over ... shops could be catching up to the newer model by now.
  10. Apr 17, 2017 at 8:57 AM
    cascadetaco
    cascadetaco Toyota Addict
    central oregon
    2017 SR 4cyl 4x4 5speed
    The shops around here didnt have a clue. I gave up and am running with the light on my dash for now. Maybe someday I can get some cloned sensors!
  11. Apr 17, 2017 at 8:59 AM
    Low Range Off-Road
    Low Range Off-Road Well-Known Member
  12. Apr 19, 2017 at 7:43 PM
    Harvo
    Harvo Hanging On !!!
    17' TRD Offroad DCSB
    SpiderTrax, RCI Sliders, Warn bumper, Smittybuilt winch, Ridge Grapplers...
    Do wheel spacers such as Spidertraxx effect the TPMS at all?
  13. Apr 19, 2017 at 7:49 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    No, they do not.
  14. Apr 19, 2017 at 9:13 PM
    Fire Arrow
    Fire Arrow Hanging out at work
    Jim
    MD
    2016 Black DCSB SR sold, 21 Tundra Limited MGM
    The tire shop I went to wanted $25 to program 4 sensors.
  15. Apr 20, 2017 at 2:34 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Why spend hundreds of $ to get new sensors for your 2nd set of tires when all you need is a 3/4" round piece of black electrical tape and a tire gauge in your center consol..???? Makes NO freekin' sense to me at all. My tire gauge worked for 50 years..... Why do I need this TPMS now..??
    I changed to winter tires last fall...tape on dash... Checked the pressures a few times over winter...no big deal.. I figure I saved about $40.00 each time I checked the pressure...That's $10.00/tire..... Makes sense to me...
    Down with TPMS and driverless vehicles and cell phones while trying to drive...!!:angrygirl::angrygirl::angrygirl::angrygirl::angrygirl:
  16. Apr 24, 2017 at 1:33 PM
    motor-vater
    motor-vater Well-Known Member
    The Schrader EZ Sensors work. Even though schrader doesn't admit or know it. The problem is the computer that most tire shops use doesnt have the gen 3 in there yet. My tire shop used a different computer to download the stock codes then just manually entered them into the Schraders and boom I have 2 sets of wheels fully interchangeable. Been working great for 3k miles so far!
  17. Nov 8, 2017 at 10:41 AM
    JasonCSU
    JasonCSU Well-Known Member
    Denver, CO
    2017 DCSB 4x4 TRD OR 6MT
    This is exactly what I have been trying to find out myself. Do you know which model of Schrader sensors you used? Thanks.
  18. Nov 8, 2017 at 1:34 PM
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    New sensors or swapping to different wheels? If the latter why would they need to be programmed?
  19. Nov 8, 2017 at 3:52 PM
    Fire Arrow
    Jim
    MD
    New sensors IIRC. It was quite awhile ago.
  20. Oct 24, 2018 at 4:08 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Think I'll run without sensors when I buy my new alloy wheels. I have some black touch up paint I can hide that yellow light on the dash.
