Tire pressure sensors
Discussion in '3rd Gen. Tacomas (2016-2023)' started by afret, Jun 22, 2021.
  1. Jun 22, 2021 at 3:17 PM
    afret
    afret [OP] Well-Known Member
    North Idaho
    2021 SR5 DCLB
    I'm thinking of getting a set of dedicated winter tires/wheels so I need to be able to reprogram the tire pressure sensors when swapping tires.
    I have a tool for reprogramming the pressure sensors (Bartec 400). I think tire shops use this type of tool. It lets you scan/activate each sensor then you hook up the tool to the OBD port on the car/truck. The latest software update that I have for it only goes up to 2019 Tacomas. Does anyone know it I use the setting for 2019 Tacomas, it would work for a 2021 without screwing anything up?
  2. Jun 22, 2021 at 4:49 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    My guess is that if it works with 2019 it will work on a 2021. They are both 3rd gen Tacoma’s. The software/firmware probably hasn’t been updated since 2019 to show 2021 as an option. This is only a guess. YMMV.
  3. Jun 22, 2021 at 5:32 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Easiest and best way is to Clone 4 aftermarket sensors (I used Autel) with the OEM TPMS ID#s.
    When you swap wheels yourself, make sure the ones removed from the truck are very far away before you start the truck. Now the truck sees the same ID#s and all you need to do is follow the directions in the owners manual about the TPMS button at your left shin.
    NoOne likes this.
  4. Jun 22, 2021 at 8:25 PM
    afret
    North Idaho
    2021 SR5 DCLB
    Hey, thanks for the great info!
