Tire Pressure Sensors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jrhzn, Dec 26, 2024.
  1. Dec 26, 2024 at 7:00 AM
    jrhzn
    jrhzn [OP] Well-Known Member
    Westminster MD
    2015 TRD PRO
    Icon stage 10 suspension, Falken Wildpeak AT3 33” tires, Leer Cap, AuCar Headunit, Morimotyo headlights and more.
    What are some creative ways that members on here have figured out how to display tire pressures? Not sure if there’s a aftermarket device or other things that can be used.
  2. Dec 26, 2024 at 8:27 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
  3. Dec 27, 2024 at 8:53 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    On my aftermarket head unit with an iDataLink Maestro RR you can display the individual tire pressures.
    I also have an OBDLinkMX+ and using the app I believe I could see the tire pressures. Haven't played with that enough to confirm, but you can see lots of info that way.
  4. Dec 27, 2024 at 2:30 PM
    Rob MacRuger
    Rob MacRuger Well-Known Member
    2006 4X4 SR5 4.0
    I have this OBDLink MX+ and it displays the tire pressures.
    Only down side is that it won't display anything else such as trans temp-etc when TPMS is selected.
    wi_taco[QUOTED] likes this.
  5. Dec 27, 2024 at 7:14 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    The newer ScanGauge can show tire pressures, do note that 2nd gens don't store tire position only sensor IDs #1-#4 (#5 prior to 09).
  6. Dec 30, 2024 at 7:02 PM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    I have a very early 2009. My TPMS light is on, but the pressures are ok. I have a scan gauge 2 and when I select the tire pressure on one of the readouts, it changes every few seconds. Is it cycling thru all four tires?
    I'm just going to take it to Discount tire and let them fix it, but I'd still like to know more about the Scan Gauge and the pressure sensors.
  7. Dec 31, 2024 at 9:21 AM
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
    Pretty sure he was referring to the newer scan gauge III. The SGII is old, it debuted in 2005.
  8. Dec 31, 2024 at 9:29 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Unsure, I never sent mine in to have it updated so it can do TPMS but tire pressure will increase and decrease slightly as the temperature of the tire changes.
    Sensors can also get flaky when they get old.
    The newer SGIIs can do TPMS, older ones can be sent in to have the firmware updated to do it but I never sent mine in.
    Steelhead Bum[QUOTED] likes this.
  9. Jan 2, 2025 at 11:34 AM
    gutsy
    gutsy Well-Known Member
    Dave
    Yardville, NJ
    Black 2010, 4 Cyl Manual TRD
    Added intermittent wipers, rear camera with Rear view mirror LED, remote door locks, Cruise control
    Here is the correct procedure for reseting your tire pressure sensors:
    If you normally inflate your tires to 35 PSI and you want to be alerted when your tire pressure is 30 PSI or less, then you would first DEFLATE ALL 4 TIRES to 30, then turn your key to "accessories", push the TPMS reset button untill it stops blinking. Then inflate your tires to 35, start the truck, and then the TPMS warning light should turn off.
    Hope this helps!
    hinmo24t likes this.
