Tire pressure transfer question
Discussion in 'Off-Topic Discussion' started by Howen, Feb 24, 2016.
  1. Feb 25, 2016 at 10:08 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I dunno if the OP is serious or not either...
  2. Feb 25, 2016 at 11:07 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    That's all well and good, but you loose that 1 psi. I prefer to capture my extra psi's in a bottle, and save them for when I need them. That way, if someone takes some psi out of a tire, you have extra saved to put some back....
    dcsbtaco and YotaGurlIAm like this.
  3. Feb 25, 2016 at 11:12 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I'm not sure about this thread, if OP is serious this could easily be in the "best of..." thread. If OP is just trolling to be a d*&k, well, it's still pretty freakin funny.
  4. Feb 25, 2016 at 11:19 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    He's totally just joking around, and it's pretty damn funny.
  5. Feb 25, 2016 at 11:39 AM
    Clearwater Bill
    Billy
    Largo Florida
    @Howen, balancing air pressures is an issue, but yours isn't too bad. If you are close to your next tire rotation and ACI, you might just wait and have the dealer do it?
    ACI (air change interval) is an important PM task too. We have dozens here adamant about 3k OCIs with synthetic.
    Not understanding their silence on this issue.
    Howen[OP] likes this.
  6. Feb 25, 2016 at 11:47 AM
    thunderbases
    thunderbases Well-Known Member
    Alabama
    15,TRD Off Road
    Almost as good as: How do I add air to the tires while the truck is moving??:facepalm:
  7. Feb 25, 2016 at 11:50 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    ACI depends on whether or not the air is being filtered. My Air Storage system is filtered, so I don't have to change it as often. My off road air is liquid Co2, so Im not sure how often Im supposed to rotate it.
  8. Feb 25, 2016 at 12:00 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Correct, OP should go back to dealer and have the TPMS properly calibrated. Adjustment procedure is covered under a Toyota Service Bulletin, 2016-ID.10-T
  9. Feb 25, 2016 at 12:19 PM
    Clearwater Bill
    Billy
    Largo Florida
    I'm taking this to the Service Advisor 4/1/16 when I make my annual visit.
  10. Feb 25, 2016 at 12:27 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    It's a fairly recent TSB that applies to the third gen models. If your Service Advisor is not sure what you are talking about, make sure you have them check with the Toyota regional Service and Parts advisor. Ammendments are probably updated weekly, as more of these challenges with the first year of the third gen are reported by customers.
  11. Feb 25, 2016 at 12:29 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    Drag 1 lb from the rear tire to the front tire on the screen. :rolleyes:
  12. Feb 25, 2016 at 12:30 PM
    Clearwater Bill
    Billy
    Largo Florida
    Works only with tech package which gets the touch screen.
  13. Feb 25, 2016 at 12:44 PM
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    Move your seat all the way forward
  14. Feb 25, 2016 at 3:00 PM
    Howen
    Howen [OP] Well-Known Member
    2016 DCSB OR M/T black w/Leer 180
    Thanks everybody for your suggestions. This seems like the only way to do it. How does everyone dispose of the extra air? Can I take it to Autozone?
  15. Feb 25, 2016 at 3:12 PM
    #35
    Deejay54
    Deejay54 Well-Known Member
    Dj
    Utah
    16 Tacoma DCSB
    I think your gonna have to fully restart the whole process completely empty all four tires of air and use a bike pump to pump them back up so you can get it a bit more accurate and then hope the weather doesn't change cuz then there gonna go all different on ya
  16. Feb 25, 2016 at 3:18 PM
    #36
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    This reminds me of last nights ordeal. My sisters tire went flat from a nail in the garage. I spent 20 minutes trying to figure out how we can get it to a shop without paying for a tow. Duh- put on the spare and get off the internet. I'm getting stupid going to the Internet to solve all my problems.
  17. Feb 25, 2016 at 3:22 PM
    #37
    Clearwater Bill
    Billy
    Largo Florida
    or take it off, put in your truck and have it fixed, then reinstall. Assuming her vehicle can be static during that time.
    Saves futzing with the spare and the second jacking.
  18. Feb 25, 2016 at 3:22 PM
    #38
    Nighthawk
    Levi
    Casper Wyoming
    I don't know if stupid is the right word, but common sense about the physical world sure has gone out the window in this digital age.
  19. Feb 25, 2016 at 3:26 PM
    #39
    Clearwater Bill
    Billy
    Largo Florida
    See post #22 above
  20. Feb 25, 2016 at 3:44 PM
    #40
    NMTrailRider
    New Mexico
    Ha that was a good one.
