tire pressure warning light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dwr80, Jan 20, 2018.
  1. Jan 20, 2018 at 7:41 AM
    dwr80
    dwr80 [OP] Well-Known Member
    recently upgraded stock tires on an 09 from 265/65/17 to 265/70/17 and the tire warning system stays on. Is that /c of the larger size tire? can the light be disabled? Or does one need to bring to dealer?
  2. Jan 20, 2018 at 8:22 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Air up your tires...
  3. Jan 20, 2018 at 8:23 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    and check spare..
  4. Jan 20, 2018 at 8:44 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    It's also possible that whomever mounted your new tires damaged a Tire Pressure Sensor during the mounting process.
    MadDaddy likes this.
  5. Jan 20, 2018 at 8:54 AM
    Clearwater Bill
    Billy
    Largo Florida
    No.
    Not really. Bulb removal is about the only sure fire way.
    Assuming you can't clear the lamp following the procedure in the owners manual, take it back to the outfit that mounted the tires.
    Keep in mind that an '09 is about the age sensors start to fail due to age and dying batteries, so it could be coincidence.
    Norton likes this.
  6. Jan 20, 2018 at 10:35 PM
    OKTACO
    OKTACO Well-Known Member
    Ty
    2005 SR5 Taco
    If the light is completely solid from the time you first start the truck its a pressure related problem as discussed could be a sensor in the spare.
    If the light flashes for a bit then goes solid there is a communication issue
  7. Jan 20, 2018 at 11:00 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    It could also be that the parameters at which the sensors were set prior to the change in size are a pound or two or three off from the current pressure of the new tires. If the techs didn't reset the light to accommodate for the update, it could account for the light being in now. You can reset the light yourself, but You should still verify that that is, in fact, the issue (ie. make sure a sensor(s) isn't in need of replacement).
    I'd reset the light according to the manual and if the light still comes on, take it in to the shop you got the tires.
  8. Jan 20, 2018 at 11:28 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    If no other problems, just place a piece of electrical tape over the light
    black coffee likes this.
  9. Jan 22, 2018 at 4:15 PM
    dwr80
    Thanks All.. 1 bad sensor.
