Tire pressure warning system
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jud, Sep 23, 2024.
  1. Sep 23, 2024 at 11:41 AM
    Jud
    Jud [OP] New Member
    Jim
    2007 Tacoma dual cab short box
    None
    I have a 2007 Tacoma and one of the tire pressure sensors is not working which is leaving a warning lite on the dash. Is it possible to remove the fuse to turn the warning lite off ? If so where is the fuse located and what is the designation of the fuse. Thanks.
  2. Sep 23, 2024 at 11:48 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Four sensors. $41. No excuse not to have working sensors.
    Amazon.com: Marsflex TPMS Sensor 42607-33021 Compatible for Toyota Rav4 Camry 4Runner Tacoma Corolla, Lexus Scion Pontiac Tire Pressure Monitoring Sensors Replacement PMV-107J 42607-33011 42607-06011 315MHz 4Pcs : Automotive
    Any tire store will install and program them for about $10 each. Or if you buy them and have them installed when you buy new tires there is no charge to install them.
    You'll be good to go for another 10 years for less than it costs to buy a tank of gas.
    I have those senors in 4 vehicles. All work perfectly and the oldest ones have been in 6 years now. I don't wait for mine to die. I buy new sensors and replace them with every other set of tires. That's about every 6-7 years. They might last a little longer, but chances are good they won't last for 3 sets of tires and it's cheaper and easier to just replace them proactively.
    They don't replace your air gauge. They warn you if you have a sudden tire deflation while driving.
  3. Sep 23, 2024 at 2:19 PM
    el_smurfo
    el_smurfo Well-Known Member
    To answer OP's question, there is not just a fuse you can remove. There are tutorials on here that show you a hack to get the light to turn off but it's a bit of a pain to do (and probably illegal if you sell the vehicle). Another option is to take the dash apart and desolder that LED.
  4. Sep 23, 2024 at 3:07 PM
    Jud
    Jud [OP] New Member
    Jim
    None
    Thanks for your reply el_smurfo.
