Tire pressure with an ATV in the bed
Discussion in 'Wheels & Tires' started by Saffa, Sep 9, 2017.
  1. Sep 9, 2017 at 9:52 AM
    Saffa
    Saffa [OP] Well-Known Member
    Victoria, British Columbia
    2015 TRD Sport DC 6MT
    Hi,
    I have just fitted 265/70 R17 Michelin Defenders on my truck, replacing worn out 265/65 R17 M/S 2's
    How much do I need to increase the tire pressure if I load my Honda 350 ATV?
    The atv weights 250kg
    I would like to keep them inflated at the higher pressure for the hunting season
    I don't drive far to work and Costco inflated it with nitrogen
  2. Sep 9, 2017 at 9:54 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    The best scenario comes from a chalk test. It's simple and there's probably a video on YouTube on how to do it. You could air up from there to increase the gas mileage slightly, but the ride and wear will suffer slightly.
  3. Sep 9, 2017 at 9:57 AM
    Saffa
    It's filled with nitrogen, I think I should have it inflated to higher pressure at Costco and then do the chalk test
  4. Sep 9, 2017 at 10:03 AM
    Saffa
    The new tires are load rated 115T compared to the 110T of the old set
    I know 115T can carry more but will it mean it would need less extra pressure to cope with the load i.e. a stronger tire carcass?
  5. Sep 9, 2017 at 10:08 AM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Honestly, set it to the pressure printed on the door label. Toyota has already done the math for you and figured out the ideal tire pressure for your truck. The difference between a 110T and 115T load rating shouldn't affect optimal tire pressure. You can load your truck up to its max load carrying capacity of the truck with the tire pressure set to what it says on the door.
  6. Sep 9, 2017 at 10:19 AM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Air is already 78% nitrogen. The whole "fill your tires up with pure nitrogen" thing is more or less a snake oil sale. There are minuscule benefits to it, but don't offset the cost of doing it in the first place.
    The new load rating can carry a higher load with more air, but that's generally only needed if you're towing or hauling an extreme load.
    This is also an option but I prefer the chalk test cause I'm OCD and all tires and all trucks are different.
    DavesTaco68 likes this.
  7. Sep 9, 2017 at 11:28 AM
    Saffa
    So adding air with my pump or at a gas station won't "ruin" the nitrogen?
  8. Sep 9, 2017 at 11:33 AM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Not sure if you can ruin nitrogen but it won't ruin anything. The air in your tires just won't be pure nitrogen, but you won't notice any difference.
  9. Sep 9, 2017 at 12:07 PM
    Styx586
    Terrance
    Lake Elsinore, Ca
    The whole nitrogen thing is nothing but a Costco upsale. As @DustStorm4x4 said the air we breathe is 78% nitrogen already. And even the "pure nitrogen" that comes out of those machines isn't 100%. There is absolutely nothing wrong with filling your tires with regular air...
    DustStorm4x4 likes this.
  10. Sep 9, 2017 at 12:16 PM
    Saffa
    They add it for free, I didn't pay for it
    Anyway, I don't drive long enough distances in warm conditions enabling the nitrogen to "work" and "cool down the tires and reduce wear" like they claim
  11. Sep 9, 2017 at 12:25 PM
    Saffa
    Oh I know I have been filling tires with air for thirty years
    Nitrogen in tires seems to be superfluous technology like TPMS systems
    Not like fuel injection and electronic ignition, I hated dealing with carburetors and contact breaker points
    Styx586[QUOTED] likes this.
