Tire pressure?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pinktaco808, May 15, 2011.
  1. May 15, 2011 at 11:14 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    i was filling my x runner tire today and was using the crappy stick tire gauge to measure the pressure.The thing is all of them was 60 psi because i used another gauge that toyota gave the dial one. Is it bad if it was 60 psi?I didnt drive around thank god. The tire are the stock x runner 18 in rims.
    Anyone can suggest a good tire gauge that is accurate and doesnt cost that much?
  2. May 15, 2011 at 11:16 PM
    jackrules
    jackrules Well-Known Member
    Jack
    San Diego
    10 PreRunner Double Cab SR5 TRD Sport LB
    i don't think it's too bad, as long as they werent driven on...
    I have an accu guage ( I think that's what it's called )
    it's digital and really accurate, not too expensive... like 15 or 20 bucks and extremely durrable.. I don't hesitate to toss it in with my tools when i'm off roading
  3. May 15, 2011 at 11:17 PM
    pinktaco808
  4. May 15, 2011 at 11:18 PM
    pinktaco808
    where did you get it from?
  5. May 15, 2011 at 11:19 PM
    pinktaco808
    how the digital ones?
  6. May 15, 2011 at 11:36 PM
    pinktaco808
    is it accurate?
  7. May 15, 2011 at 11:41 PM
    jackrules
    Jack
    San Diego
    digital ones are very accurate. I love mine, that vaiar one should be good. Theres another one that is amazing that my grandpa has, but i'm not sure what the make is... i'll check next time i'm there
  8. May 15, 2011 at 11:48 PM
    808matt
    808matt Well-Known Member
    hawaii
    19 Ranger
    i would think it wouldnt be "well worth the money" if it wasnt accurate...
  9. May 15, 2011 at 11:49 PM
    pinktaco808
  10. May 15, 2011 at 11:51 PM
    jackrules
    Jack
    San Diego
  11. May 15, 2011 at 11:52 PM
    jackrules
    Jack
    San Diego
    those 3 from orille look cheap to me..
  12. May 15, 2011 at 11:55 PM
    pinktaco808
    so not good? what be good from orielly or sears?
  13. May 15, 2011 at 11:59 PM
    808matt
    hawaii
    19 Ranger
  14. May 16, 2011 at 6:26 AM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Considering your tire sidewall says either 50psi(stock dunlops) max or 35 psi max (many p-metric) , depending load range, I dont think i'd want to hit the freeway at 60psi.
    Just a side thought here though on higher load range,any new tires tire might be load range D or even E ....if a person asked for them, they have more plies and can hold more psi. The rims' max pressure then becomes the limit and ive never seen psi on a rim only load max in weight, basicly whichever is lower, the extra plies are more durable offroad , but the higher psi capability is not needed on a tacoma.
