Tire pressure
Discussion in '5 Lug' started by DrunkenDangler, Jul 9, 2011.
  1. Jul 9, 2011 at 8:36 AM
    DrunkenDangler
    DrunkenDangler [OP] Well-Known Member
    AL
    2005 5 lug access cab
    fat bob lift
    I had some new tires and rims put on my 5 lug a weeks ago. 15x8 on 30s and the max psi is 50 on the tire. I checked my tires the other day and it was on 32 should i increase the tire pressure to 45 or leave it at what the tire shop set it at?
  2. Jul 9, 2011 at 8:37 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Chalk line test will give you the best answer. Search for it.
  3. Jul 9, 2011 at 1:51 PM
    DrunkenDangler
    AL
    fat bob lift
    I dont have any chalk :confused::confused::confused::confused:
  4. Jul 9, 2011 at 1:58 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Seriously?? Then I guess you are stuck using the pressure the tire place set them at.
    Best of luck!!!
  5. Jul 9, 2011 at 2:23 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Do you have any stores ?
  6. Jul 9, 2011 at 2:26 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Look on the inside of the drivers door. It should show you what your truck's PSI should be at. A chalk test would get you a little more accurate, but following the door isn't going to get you into any trouble.
  7. Jul 9, 2011 at 2:30 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    But be aware that the numbers posted there are "ideal" for the OEM tires on the OEM configuration. If you've added more weight (or removed some) form the truck or installed different tires...Those pressures (while maybe close by luck) are more or less irrelevant.
  8. Jul 9, 2011 at 2:40 PM
    bcb97
    bcb97 Well-Known Member
    Seems like I read in a Popular Mechanics one time that its best to have your tires 10 under the max psi for the best ride and wear pattern without sacrificing MPG. The stealership had my tires at 35 which is the max and I put all 4 down to 30 and noticed the ride was much better.
  9. Jul 12, 2011 at 8:23 PM
    scott572011
    scott572011 Well-Known Member
    SCOTT
    SO-CAL.
    THE RELENTLESS PRUIST....
    BF GOODRICH T/A ko, BILSTEIN HDs, AMERICAN RACING RAZOR`S 16X7.5, READYLIFT SST HYBRID LIFT SYSTEMS, ALTEC LANSING AUDIO,DREGS OF THE EARTH SYSTEMS,WOLF EYES,SUREFIRE ILLUMINATION TOOLS,HK-PROTECTION!!. POP LOCK, SHORTY ANTENNA, TACO TENT #3,. NITECORE ILLUMINATION, FENIX FLASHLITES. STILL PROTECTOR`S, FACTORY BED MAT, CUSTOM BED WEB, INTRO-TECH INTRO-GUARD CUSTOM TRUCK COVER, CENTER CONSOLE LOCK MOD, TECH-SHADE M1068, WEATHER-TECH CLEAR-COVER`S, OEM MINI TIE-DOWNS, TRUCK BEDZ AIR MATTRESS EXPEDITION SERIES, McGARD TOUGH NUTS WHEEL LOCK`S, DISABLE SEAT/BELT CHIME MOD, GARMIN GPS, KERSHAW BLADE`S, SKELETOOL, WEATHER-TECH FLOORLINER DIGITAL-FIT GRAY # 461781, NITE(IZE) KNOT-BONE ADJUSTABLE BUNGEE SYSTEM, WET OKole SEAT COVERS, UNDER DASH FLYZEYE BW LED LIGHT W/CUSTOM BLUE HALOS. NITECORE IFE1 INFILUX ILLUMINATION SYSTEM. JETBEAM BC-10 HANDHELD, HK VP-70Z 9mm PROTECTION!. JETBEAM PC-10 550 LUMEN ILLUMINATION SYSTEM. SUREFIRE E2D-LED-DEFENDER ULTRA 500 LUMENS KICK ASS ILLUMINATION...VIPER ALARM SYSTEM`S,ROCKFORD FOSGATE POWER COMPONENT SYSTEM`S.KENWOOD AUDIO/VIDEO,HUSHMAT SOUND DEADENING INSULATION,3M AUTOMOTIVE FILMS.
    Brunes is on the money. :No chalk Umm. you could all-ways use your!!!!...!! .Different tires, different drivers, highway Vrs, trail, ect.....
  10. Jul 12, 2011 at 8:46 PM
    scott572011
    SCOTT
    SO-CAL.
    LOL,LOl,lol,lol, could not have said it better!!. except: "NO BRAIN NO HEADACHE"
