tire pressure?
Discussion in 'Wheels & Tires' started by Menametony, Jan 20, 2009.
  1. Jan 20, 2009 at 8:22 PM
    Menametony
    Menametony [OP] Well-Known Member
    Tony
    San Diego
    09 Black 4x4 DC Offroad
    Flow Master 40 Series, TRD CAI, Kings 2.5 remote res front and back, All Pro Front bumper, All Pro Skid Plate, PIAA 4" 510 XT SMR, TC UCA's, 265/75/16 WildPeak AT3 on ATX Artillery, LightForce 240 Blitz HID's, WeatherTech Vents and FloorMats, Cobra 19 CB & PA, Maglite mod both driver and passenger, safari snorkel, TRD supercharger, warn 10k winch, PRINSU CabRack, Cali Raised 42" Light Bar,
  2. Jan 20, 2009 at 8:29 PM
    Simon's Mom
    Judy or Jude :)
    SBurl Vermont
    13 TRD OR DC MGM
    Stock for now
    Your door jamb has a plate with pressure settings, I think 29 psi front & 32 psi rear recommended, I run it higher in the winter myself.
  3. Jan 20, 2009 at 8:30 PM
    Menametony
    Tony
    San Diego
    oh ok.. i look in the morning.. i have this picture i took yesterday and my front passenger tire looks low? for some reason i can upload pictures right now.. ill upload them when i can.. thanks
  4. Jan 20, 2009 at 8:36 PM
    dunkhi
    dunkhi CSULB socal
    Craig Sirois
    Southern California. Fountain Valley
    09 Ivan Stewart
    Toytec Coilover kit. Bilstein's 5100. Alcoa Wheels. General Tires. Magnaflow Cat-back. BLHM. Yellow fogs. 13TW5 jl sub. Stewart Decals.
    i set to 30 psi all around but then again im in so cal.
    works well for all terrain.
    cept dunes of course.
  5. Jan 20, 2009 at 8:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Chalk meathod
  6. Jan 20, 2009 at 9:12 PM
    Ezriderga
    Ezriderga Well-Known Member
    Georgia
    '06 Tacoma xtracab BB
    I've been running 35 in my truck and car for years. Rotate every 10k front to rear. Excellent tire wear, no problems.
  7. Jan 21, 2009 at 6:22 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Great method but what PSI did that result in for you?
  8. Jan 21, 2009 at 6:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    32 front, 29 rear.
  9. Jan 21, 2009 at 7:19 AM
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    hmmmmmmmmm, not really the results I wanted to hear but it makes sense why that's in the door then.:D
  10. Jan 21, 2009 at 7:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They (Toyota) lists a higher psi for the rear tires for when hauling a load with the OEM tires. I tell everyone to use the chalk meathod because every tire is going to distribute the load differently. For example, when I haul my boat, I raise my rear tire psi to 31#.
  11. Jan 21, 2009 at 7:56 AM
    rc2125
    rc2125 Well-Known Member
    Indiana/Michigan border
    09 TRD
    34psi here. The factory/door jamb pressures are almost always to low, especially on 16" wheels with 32" tires. High speed handling with tires that "roll" cuz there isn't enough pressure in them, can be shady. If the tires have sidewall bulge even when air'd to the recommended psi, then the manufacturer did a poor job in specifying the factory tires on the vehicle.
  12. Jan 21, 2009 at 8:24 AM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    Same pressure here, so far so good.
  13. Jan 21, 2009 at 8:40 AM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    I run 32 psi on all four tires. No problems.
  14. Jan 21, 2009 at 9:28 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    38 in front and 36 in rear, using chalk method.
  15. Jan 30, 2009 at 4:16 PM
    2009tacomav6
    2009tacomav6 Well-Known Member
    phx AZ
    2012 4x4
    TRD SC TRD Cat Back KMC 17x9 Addicts
    i would agree with higher pressures. I found when I ran the pressures listed my tire shop told me I underinflated my tires and as such would not warranty them out. Now I run closer to max pressures. My current tires, non oem, are michelin LTX. Best ones on the market that I have found for tread ware and handling. They have a max pressure of 44 and now I run them up around 39/37 or 36/34 front to back. Just depends on what I feel like. Plus with these pressure settings I found that I was getting better gas mileage as the tire was not so resistant to the ground. rolled better.
  16. Jan 30, 2009 at 4:27 PM
    Brunes
    Brunes abides.
    Rotorhead
    The important thing that hasn't been said about that door plate is it's only for the OEM tires....If you put different tires on it that plate is useless....
    and much like the all knowing Chris- Lil higher in front and right around 30 works great for me....18 all the way around on the trails. I haven't towed anything heavy enuf to warrant a chalk test for towing yet.
    I want some Terra Grapplers- and those I'll be runnin near 50 or 55 I think...Maybe higher.
  17. Feb 3, 2009 at 7:22 PM
    2009tacomav6
    phx AZ
    2012 4x4
    just picked up some new 17 inch michelin atx m/s. Their max pressure is a low 35! Cannot beleive it... oh well. Running 32 in them.
  18. Feb 3, 2009 at 8:17 PM
    GTB
    GTB New Member
    2009 Xtra Cab 4x2
    ARE Shell
    I just bumped it up to 35 x 4. It feels a little more rough, but I am hoping for better mileage.
  19. Feb 3, 2009 at 8:23 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    I keep mine at 35.
  20. Feb 3, 2009 at 8:25 PM
    6shooter
    6shooter Well-Known Member
    portland, or
    06 sport........
    plenty.......
    i run 30-32 in all 4 all the time.
