Tire Pressure ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by milo, Dec 13, 2013.
  1. Dec 13, 2013 at 8:03 PM
    milo
    milo [OP] Active Member
    George
    Ala.
    stock
    none
    Tps light stays on, put 35 psi all the around, still on, a friend told me he puts 50 psi cold, damn, speaking of Fred Flintstone ride, What is your input ?, Have 265-70-16 street tires, on 08 Prerunner 4 door Thanks in advance , Milo
  2. Dec 13, 2013 at 8:08 PM
    Joe D
    Joe D .
    I'm guessing bad sensor. Have you reset the system?
  3. Dec 13, 2013 at 8:11 PM
    PinkTaco24
    PinkTaco24 Well-Known Member
    NC
    06 prerunner
    5100s all around -- 1.75 fronts, 1.5 aal, spidertraxs, grillcraft mx, derped scoop & badges, AVID step bars....need.more.money.
    Check the spare?
  4. Dec 13, 2013 at 8:13 PM
    hmcclung
    hmcclung Well-Known Member
    Heath
    St. Louis
    14 Superwhite S/C DCSB TRD OR
    My vote as well.
  5. Dec 13, 2013 at 8:16 PM
    Joe D
    Joe D .
    Depends on the model year but, yea that too. :D
    ON EDIT: Found he has a 2008 so def could be.
  6. Dec 13, 2013 at 8:35 PM
    aboutmillions
    aboutmillions Well-Known Member
    had a 2008, same thing happen to me and it turned out to be the spare
  7. Dec 13, 2013 at 8:52 PM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Yep... in the winter the spare stays cold when the others heat up... when there's around a 8 psi difference it will trigger the light. In the winter take the spare up a few pounds above the other 4 to compensate for this. Don't forget to reset the system.
