Tire Pressure
Discussion in '1st Gen. Tacomas (1995-2004)' started by crazyasu45, May 27, 2009.
  1. May 27, 2009 at 2:34 PM
    crazyasu45
    crazyasu45 [OP] Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    FYI
    3" Suspension Lift...2.5" Body Lift...33" Tires...285/70/R17 Xtreme M/T
    My question is...what psi should I inflate my tires to? Max PSI on tires reads 65psi (cold) door jamb reads FRT 26psi RR 29psi
    Should I be running around 45psi?
    Thanks,
  2. May 27, 2009 at 2:37 PM
    ST77
    ST77 Wandering doesn't mean you're lost
    Brian
    Sandy, Or
    2018 TRD OR DCSB
    Bone Stock
    I'm running 32psi all around on mine...
  3. May 27, 2009 at 2:39 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i was running 34 to 35 all the way around on mine, but im gonna knock psi down a bit, my truck shakes bad enough as it is, so a lil less air may soak it up a bit better. i think 26/29 is too low though.
