Tire pressure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kanelakos, Dec 27, 2015.
  1. Dec 27, 2015 at 10:30 AM
    King Dad
    King Dad Active Member
    2013 Toyota Tacoma Prerunner
    never use nitrogen, waste of money and time by driving somewhere to get it
  2. Dec 27, 2015 at 10:51 AM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Because lots of us have figured out decades ago that running 35+ psi does not compromise the contact patch, performance, ride and longevity.
    3dBdown and CusterFan like this.
  3. Dec 27, 2015 at 11:20 AM
    mello03
    mello03 Dr. Dirty
    Greensboro, NC
    2020 F250 6.7
    Thanks for the scientific explanation. That make perfect sense.
    TacoTruckr likes this.
  4. Dec 27, 2015 at 11:22 AM
    mello03
    mello03 Dr. Dirty
    Greensboro, NC
    2020 F250 6.7
    Maybe tire manufacturers should just put on the door sill, "run them as high as you can to achieve the best mpg" lmao
    TacoTruckr and kanelakos[OP] like this.
  5. Dec 27, 2015 at 11:27 AM
    worthywads
    You believe there was science involved in picking the door label pressure?
    Funny how lots of people make all kinds of mods from stock on their truck, but OMG don't risk changing tire pressure from what the door label says.
    I've run max sidewall with no adverse results including wear, which seems to be better at high pressure.
    Z50king and CusterFan like this.
  6. Dec 27, 2015 at 11:37 AM
    mello03
    mello03 Dr. Dirty
    Greensboro, NC
    2020 F250 6.7
    Oh no, there's no science at all in that. None. Some dipshit sits at the end of the assembly line and puts a random freakin sticker on any given truck pulled out of a fishbowl. But who am I to argue with someone who sports the title of "expert hypermiler." You've clearly done your own research on the road and you're proud of it. Go run max pressure sidewall pressures and post up those mpg numbers lol.
  7. Dec 27, 2015 at 11:41 AM
    worthywads
    I do, and I'll continue to, and I'll let people know my experience.
    You stick to a sticker that has more to do with comfort than science.
  8. Dec 27, 2015 at 12:18 PM
    mello03
    mello03 Dr. Dirty
    Greensboro, NC
    2020 F250 6.7
    You run max sidewall pressures all day long, but please don't advise others her to do the same. You can heat your tires up and have a blowout if you want, but don't claim to others that just because you've had no "Ill effects" it's safe and scientific. You are clearly smarter than the engineers involved in making these decisions. Oh wait, there is no science in any of this. You win.
  9. Dec 27, 2015 at 12:22 PM
    2010gl1800
    2010gl1800 Active Member
    Barry
    Heber AZ
    2016 Tacoma TRD Off Road Access Cab
    I don't recall all of the issue but I seem to recall Ford putting a sticker on the door sill utilizing a different pressure than Firestone recommended. After lots of blowouts, Firestone got a bad name when actually Ford recommended an improper pressure. Please note: This is only as I recall and may be inaccurate. I'm hoping Toyota and the tire manufacturers agree from testing that both have done that the posted pressure is a recommended safe pressure. Now, you may run a higher pressure and get better gas mileage or less to get a smoother ride BUT, you take a risk. I would say the further you go from the recommended, the more the risk. In this "let's sue" country mentality, suppose: as worthhywads does, you typically run a tire pressure 5ish pounds above the Mfg recommended pressure. The fancy onboard computer tracks this. You are involved in an accident maybe or maybe not tire related. Cops and insurance companies pull the data, (of which Toyota says they will allow), and ....well, now we lawyers involved and .....
    I don't believe the stickers are arbitrary. I think there is some "science" in them. I also believe there are tolerances because I know that 5 tire pressure gages will read probably 3 different pressures that may vary by 5 to10%. So one person's 30psi could be another's 27 or 33psi. I also know the pressure on the instrument display will also vary from different gages. My sticker says 30psi. I go with 30 to 32psi knowing I'm somewhere in tolerance further referencing it to the instrument display. 35psi? A little high to argue gage tolerances but, that's a risk that if you're willing to take, great. I have absolutely no problems with taking risks when those risks pertain to me. But, be careful. If the risk you take can effect someone else, there's those damn lawyers again. I hate lawyers.
    All of this is imho and doesn't mean js.
  10. Dec 27, 2015 at 12:26 PM
    worthywads
    Underinflation causes heat, get your science right.
  11. Dec 27, 2015 at 1:12 PM
    mello03
    mello03 Dr. Dirty
    Greensboro, NC
    2020 F250 6.7
    No kidding. I'm talking about running max tire pressures/heat/uneven tire wear being a recipe for disaster. Now you want to talk about science lol.
  12. Dec 27, 2015 at 1:15 PM
    worthywads
    Max pressure lower temperature, uneven wear haven't seen it, no disaster. Been max pressure since 1988, I'd think I'd have noticed uneven wear, but I haven't. Long tire life too.
  13. Dec 27, 2015 at 1:15 PM
    Drifter16
    Drifter16 Well-Known Member
    Eric
    Shenandoah Valley Area
    2016 Blazing Blue Pearl TRD O/R, DCSB 4x4,Prem Tech JBL
    Offensive stickers and stuff the wife doesn't know about.
    That's why costco is great they only use Nitro now and they always seem to have some sort of rebate on one of the big brands.
  14. Dec 27, 2015 at 1:19 PM
    kanelakos
    kanelakos [OP] Well-Known Member
    Binghamton, NY
    16 DC LB Sport
    Drove around for awhile starting out at 30 cold psi. Went up only 2 psi while driving (cool and rainy). Seemed to ride smoother. Still need to figure out why dealer or Toyota had it at 35 cold when spec says otherwise.
  15. Dec 27, 2015 at 1:25 PM
    #35
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
  16. Dec 27, 2015 at 1:27 PM
    #36
    undertaker
    undertaker Just work and play
    Arkansas
    2013 DC TSS
    Stock
    Been running pressure stated on the door since new and at 40000 no problems to speak of.
    As for nitrogen in the tires, that is what came in them, but the SM told me not to worry about it and use air when the time came.
    I have a couple of tires with air in them now due to flats.
    Have not noticed no change.
  17. Dec 27, 2015 at 1:59 PM
    #37
    Farmer_Ted
    Farmer_Ted I WANT A TACO!
    Mid West
    '16 Tacoma SR AC 4X4 MT
    Hardcore off road floor mats!
    I know a guy that works at a local (to me) community college. The college had to spend money or lose it. They bought a $10k nitrogen machine. So he puts nitrogen in his tires for now on. It's free for him...
    What a waste.
  18. Dec 27, 2015 at 2:18 PM
    #38
    Joe D
    Joe D .
    Every single time I take mine in for tire rotation they move my PSI to 35.
  19. Dec 27, 2015 at 3:51 PM
    #39
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    Mine came with 40PSI in the tires. I've left it at that
  20. Dec 27, 2015 at 4:10 PM
    #40
    worthywads
    You are a disaster waiting to happen, but with a good lawyer it will be Toyotas fault. Hope you live. ;)
