Tire pressure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by leineboy, Mar 5, 2017.
  1. Mar 5, 2017 at 10:52 PM
    c4lvinnn
    c4lvinnn Well-Known Member
    '17 TRD Off Road DCSB
    Pretty sure because they arent moving from a p-load range to a c or LT/E.
  2. Mar 5, 2017 at 10:53 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Point is, if goodyear says you should run a particular psi why would you question them. But hey everyone else knows more.
    OP has enough here to figure it out.
    Cheers.
  3. Mar 5, 2017 at 10:56 PM
    jake slatnick
    jake slatnick Well-Known Member
    jake
    San Diego
    Cement TRD Pro
    285/75r16 KO2's, Baja XL 80's on CBI ditch brackets, TRD intake, opticoat pro, clear bra running the bottom sides, morimoto LEDs, all white LEDs inside, mounted shovel and axe above wheel well in the bed, linex'd the bed...
    I have E rated ko2s that are 285 75 16. Run that at 32psi. Way smoother ride.
    An E tire is made for a heavy truck. If you run them on light trucks, you want the tire pressure lower so that the tire wears evenly across the tread. If you run something like 50, not only are you going to feel every spec of dust on the road, but because your truck isn't heavy enough for the tire, it will bow out at the center and not give you the lifetime you're looking for.
    And to Joe who wants to talk about Ferrari... I was given this information directly from a Ferrari employed mechanic. Just saying o_O
    c4lvinnn likes this.
  4. Mar 5, 2017 at 10:59 PM
    c4lvinnn
    Because logically it goes like this:
    >OEM tires are P load and is what? 34psi or something max load
    >Is it comfortable for most people? Yes.
    >LT/E to retain max load is 50-55psi
    >Is it comfortable for most people? No.
    >Back down the pressure until its more comfortable and adjust to your load. 9/10 times you wont even come close to max load or GVW so you'll be fine dailying at a lower pressure
    Goodyear tells you that to answer your direct question of what should I run if I went to E rated tires for my taco [to keep load capacity]. They dont care about the other nuances or subjective items such as tire wear (light truck, high PSI), or comfort.
  5. Mar 5, 2017 at 11:00 PM
    JoeCOVA
    Joe
    Colorado Springs
    After 50k miles I'll let you know how the tread is.
    For the F-250 tires wore even until 60k at 65 front 75 rear, Michelin LTX/AT2
  6. Mar 5, 2017 at 11:02 PM
    c4lvinnn
    I sure hope so when that truck is what? 1500lbs or more heavier than the taco? I'm not sure why you keep comparing a full ton truck to our truck lol
  7. Mar 5, 2017 at 11:03 PM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    Makes my bones hurt thinking about all of the vibrations from running such a high PSI... And I feel bad for the vehicle absorbing all of the shock that the tires aren't... But that aside, the f250 probably has a few thousand pounds on the Tacoma.
  8. Mar 5, 2017 at 11:03 PM
    JoeCOVA
    Joe
    Colorado Springs
    Because my taco weighs the same as that F-250 unloaded.
  9. Mar 5, 2017 at 11:05 PM
    JoeCOVA
    Joe
    Colorado Springs
    Negative. They weigh almost the same and the truck lasted 250,000 miles before rust killed it.
  10. Mar 5, 2017 at 11:06 PM
    c4lvinnn
    So, did you see my logic in my other post? "And adjust to your load?"
    Most people will not like and want 50+ psi on their unloaded trucks. I dont see why you have a hard time grasping not everyone has a fully armored truck like you do, so obviously their pressures will be more comfortable at a lower PSI than yours is at.
  11. Mar 5, 2017 at 11:07 PM
    JoeCOVA
    Joe
    Colorado Springs
    I don't disagree. Why do you have a hard time grasping that people don't mind running manufacturer specs?
  12. Mar 5, 2017 at 11:08 PM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    Based on Google the f250 weighs 6,000 and the Tacoma weighs less than 4,000.
    But hypothetically, even if the tires should be at a higher PSI to last longer (which is the only benefit I can see from that), I'd rather have a smooth and comfortable ride for 40,000 miles with a truck that hasn't rattled apart and doesn't creak at every bump, than tires that last 60,000 and have given me the opposite, uncomfortable experience.
  13. Mar 5, 2017 at 11:10 PM
    JoeCOVA
    Joe
    Colorado Springs
    Very inaccurate. My trucked weighed about 5000 lbs and google says taco weighs 4480. Just google curb weight.
  14. Mar 5, 2017 at 11:10 PM
    Bishop84
    Bishop84 Well-Known Member
    This thread has nothing to do with F250s, it's a light truck with a heavy tire. Towing capacities dictate tire specs.
    I work on tons of these and Tundras and all that run above 40psi on LT tires burn the center section of tread.
    Tire squat is part of the design and intention of the tire, if you have none then you have a very limited patch of traction. You bump it up for load. Tire manufacturers only set maximums.
    mello03 and c4lvinnn like this.
  15. Mar 5, 2017 at 11:10 PM
    #35
    c4lvinnn
    9 out of 10 people with stock unloaded tacos will NOT run manufacture's recommended specs at 50+ psi.
    You have a fully armored truck. I would probably run that too, with that weight. Did you have those tires before you fully armored up and had a stock truck? If so, did you run at 50 too?
  16. Mar 5, 2017 at 11:12 PM
    #36
    JoeCOVA
    Joe
    Colorado Springs
    Yes
    I also didn't notice a huge difference running high PSI on the Ford as far as ride comfort.
  17. Mar 5, 2017 at 11:12 PM
    #37
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    @smitty99 what do you have to say about all of this?
  18. Mar 5, 2017 at 11:13 PM
    #38
    c4lvinnn
    I bet it was a harsher ride but you (subjectively) didnt mind it. Or dont take into consideration any subjective feelings/opinions and just run whatever the manufacturer said. Which is ok, but you're not the majority.
  19. Mar 5, 2017 at 11:14 PM
    #39
    JoeCOVA
    Joe
    Colorado Springs
    True I probably just don't pay as much attention to it. My concern is load rating and tire wear.
  20. Mar 5, 2017 at 11:16 PM
    #40
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    Tire wear :thumbsup:
