Tire pressure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dsixnero, Aug 29, 2017.
  1. Aug 29, 2017 at 4:16 PM
    dsixnero
    dsixnero [OP] Well-Known Member
    Dan
    2016 Tacoma TRD Off Road White
    None yet
    My TRD-OR-AC says to keep tires at 30 lbs. Now I have a tire warning because one tire is at 29 lbs, wtf, I wonder if everyone is doing the 30 lbs
  2. Aug 29, 2017 at 4:20 PM
    Clearwater Bill
    Billy
    Largo Florida
    Doesn't matter what you chose to run.
    As long as they are all the same the TPMS will be happy, although 1# delta seems a little sensitive.
    But the thing is so stupid you can put one side of the truck in the sun and the other in a cold shadow (pressures change ~1# per 10* up or down) and it will light it up.
    Regarding running pressure, you should experiment using the standard tread chalk test an arrive at your own optimum pressure. If you are still running OE tires, 30 is probably the right starting point.
  3. Aug 29, 2017 at 6:58 PM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    OE tires, do what the door says. After Market, do your homework.
    G.
    Blazingbluesport likes this.
  4. Aug 29, 2017 at 7:27 PM
    .jake
    .jake Ex-Lion Tamer
    Discharged from the Whale’s Vagina into Mesa, AZ
    0x07E1 4x4 DCLB TRD Sport
    2" Lift on 16x8 -12 SCS Ray 10's w/ 265/75 Wildpeaks
    I'd be lucky if my tires were within a pound across the truck.
  5. Aug 29, 2017 at 7:48 PM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    dsixnero, the system has a threshold set for certain percentage below the preset value. I forgot what the percentage difference was before it triggers the light, you can reset your TPMS again when all tires are at 30 or however you stagger the front/rear pressure. Once you reset the TPMS system and drive for a few miles, it will learn where your new baseline pressure values are and your one "odd" sensor should equalize with the rest, when the TPMS ECU sets.
