Tire & Pressure
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FLTacomaDad, Aug 23, 2018.
  1. Aug 24, 2018 at 12:40 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  2. Aug 24, 2018 at 1:59 PM
    Dubiousveracity
    Dubiousveracity Well-Known Member
    2018 TRDOR DCSB MT
    none
    Yeah, could see those words verbatim with the one change of daughter to son. Let's hang off on crucifying the guy.
  3. Aug 24, 2018 at 2:41 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I just felt he only had negative things to say about his kid.
    I’d be over the moon to have a daughter into trucks. I’d be using it as an excuse to spend time with her and teach her to off road.
    I wouldn’t stiffle it.
    Its not everyday you share interests with your kid.
    And a girl can learn to drive a 6cyl, manual, with 285s ;D!!
    OP... get your daughter a 6cyl and go spend some time with her getting stuck, breaking shit, and fixing it together.
    Just my 2 cents
  4. Aug 24, 2018 at 3:40 PM
    Boyk1182
    Boyk1182 Well-Known Member
    Northern Colorado
    So how much PSI for a girl? For a boy? Is it different? I didn’t read all this, but wow..
  5. Aug 24, 2018 at 4:16 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    OP, the tire size that came with your truck(245/75/16) is not the OEM size for a 4cyl. Your truck should've came with the much smaller 215/70/15 wheel/tire set. Your truck will have much more pep/mpg for a 4cyl if you simply downgrade to the original size due to the correct axle gearing(26" tire vs 30" tire). Your current size tire is for the more heavier 6 cyl tacomas and likely that the tires are not P-rated tires that your truck was originally outfitted with.
    Changing to the original tire size in a P-metric tire size will make a noticeable improvement in ride quality and drivability along with correcting the speedometer readings due to incorrect OEM tire size.
    DGXR likes this.
  6. Aug 24, 2018 at 5:22 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    On my old T-100 and now on my Tacoma, I run 35 in the front and 32 in the rear unless I'm going to haul something. Then I'll up the rears accordingly.
    I keep my vehicles for a long time and have replaced several sets of tires over the years. At these pressures, I get pretty even wear.
    Of course, it will vary depending on tire size and vehicle weight, but this is what I run and I check them about once a month.
  7. Aug 24, 2018 at 7:36 PM
    FLTacomaDad
    FLTacomaDad [OP] Member
    Ok it's not a daughter or girl thing.... I have two daughters and throughout the years we have done several things together, dirt biking and 4 wheeling to name a couple.
    Yes, it would be great to do some off-roading with her! I also nothing but proud of my daughter! She is a senior in High School playing varsity volleyball and varsity softball. She is also dual enrolled and is on track to graduate with a Associates Degree the same time she graduates High School. Finally she is on a Showcase Softball team trying to get noticed by colleges so most weekends are spent on a softball field. Not much time left for off-roading.
    4cyl would be easier on gas there for less expensive for her to use, when she goes to college. Not sure she won't end up off-roading. Yes, I am teaching her to drive a stick shift, not to own a stick just so she knows how.
    Also yes I am knew to the forum, I will try to chose my words better next time.
    Thanks for all the input.
    BillsSR5 and Boyk1182 like this.
  8. Aug 24, 2018 at 8:56 PM
    winkel
    Corydon, IN
    You didn't say anything wrong.
  9. Aug 25, 2018 at 6:42 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    a 4 cylinder pre runner truck is a great vehicle to start off with for a son or a daughter, also since your in Fla. you wont have to worry too much about snow/ice so the 2wd will be perfect fit. and the 4 banger is pretty easy for DIY maintainence
