Tire Pressure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jpepe3691, May 17, 2019.
  1. May 17, 2019 at 7:26 AM
    jpepe3691
    jpepe3691 [OP] Active Member
    2016 White Tacoma TRD Sport
    The placard on my 2016 Tacoma TRD Sport 4x4 says 29 lbs front and back. I noticed the other day the dash is reporting 35 and 36 lbs. I just brought the truck in for warranty repair for the BSM failure- I thought they are supposed to check other stuff while it's there, but no big deal.
    My questions are:
    1. Should I lower the pressure down to the recommended 29 lbs?
    2. What is the downside of keeping the tires at 35lbs?
    3. If I do lower them down to the recommended 29 lbs, do I simply have to press the tire pressure setting button on the dash? I think the manual says I have to drive it for 10 miles at 35 mph or higher first?
  2. May 17, 2019 at 7:33 AM
    TheGoat
    TheGoat Well-Known Member
    Justin
    Greenville, SC
    White 07 SR5 4x4 6spd
    OME 885 springs on 90000 shocks, sway bar removed 1.5" AAL on 285/75/16s
    To high psi can cause the middle of your tire tread to wear faster than the shoulders.
    Don't trust dealerships to do good work. My truck had a clutch job done at a dealer in Pennsylvania before i bought it. They left a bracket loose and a bolt halfway hanging out of the transmission.
  3. May 17, 2019 at 7:56 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I run 34psi (Cold) in my tires.
