Tire Pressure?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Falcon5Romeo, Feb 5, 2020.
  1. Feb 5, 2020 at 8:49 AM
    Falcon5Romeo
    Falcon5Romeo [OP] Active Member
    Tex
    2019 Tacoma SR5 Magnetic Gray
    I mentioned the 'bulge' because I noticed that none of the other 25 cars in my workplace parking lot is bulging like that. Even at 32 psi, they looked like they were going flat.
  2. Feb 5, 2020 at 8:51 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    No. Cold makes air dense and occupy less space, reducing pressure.
    TartanEagle likes this.
  3. Feb 5, 2020 at 8:56 AM
    Alnmike
    Alnmike Well-Known Member
    PNW
    '21 4R
    I filled to 43 psi and am not dead yet. I figure some highway driving wear will offset the 15psi dirt driving wear. But I also have steel skids, sliders, bigger tires, a diamondback, am fat, ect ect.
    Ol'gray mare and Dirk Diggler like this.
  4. Feb 5, 2020 at 9:03 AM
    Tmaloy
    Tmaloy Well-Known Member
    Troy
    2019 SR DC LB
    My 2019 SR DCLB I run at 36F 35R. Y spoke factory alloy wheels with Toyo Open Country A30 tires stock from purchased when picked up from the dealer. Seems to be the best ride and comfort for me, previously they were around 29 PSI and when hitting bumps, etc. the ride seemed harsh and a little jarring at the lower temp. Also, I downloaded the Tyre Assistant app from the Android app store and have the Carista App and OBD and use these to check my tire pressure. I regulary check my PSI with the app on my Samsung S8 phone. Various readings depending on time of day, temps, and what not. From personal observations, temps stay within 1-2 degrees. Last check was at 35.9 front and 34.8 rear. Ride comfort was much improved compared to when they were under 30. I keep a Ryobi inflator in the truck and check once a month at least. MPG seems to have improved by 1-2 MPG after the pressure increase and chalk test shows better contact patch on road, Wet tire performance to me was much improved also. I plan to upgrade to the Yokohama Geolander MT G003 (255 85R 16) in the future after my current tires wear out. Truck is a daily driver/commuter with very little off road use at the moment. Just a few dirt road trails so far nothing demanding. I do want the Yokos though, as I think they make any 4WD look like a beast.
  5. Feb 5, 2020 at 9:06 AM
    taco abbo
    taco abbo Well-Known Member
    rob
    Ellsworth,Ohio
    2018 tacoma trd off road
    TRD Pro Grille
    My dealer sets mine at 35 when in for oil or tire rotations
    CusterFan likes this.
  6. Feb 5, 2020 at 9:20 AM
    CrippledHo
    CrippledHo I'm calling about your car's extended warranty
    Eric
    Biggest Little Dumpster
    2016 DCSB Diet Coke
    Dents and a rattle can
    It's a recommended psi. I run higher. I just wouldn't go above that "max psi" it says on your tires
    Big tall dave likes this.
  7. Feb 5, 2020 at 9:21 AM
    BSFord
    BSFord Well-Known Member
    2018 TRD Sport 4x4
    Clazzio PVC Seat Covers Dashcam install TRD Pro Grill MESO Total Tail Stage 1 Tailgate Lock vled total interior light upgrade TRD Pro Shift knob N2 Designs Autostart w/ smart phone module
    It's both air temp and time. Even tires on a car in the showroom will lose pressure over time even if ambient air temps are constant. But I believe air tempature plays a bigger role and we notice it much more.
  8. Feb 5, 2020 at 9:25 AM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    I always love the psi threads. The conclusions and decisions people make are entertaining.
  9. Feb 5, 2020 at 9:28 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    How's my bulge look to you?
    C41n, Rockefelluh, Alnmike and 7 others like this.
  10. Feb 5, 2020 at 9:29 AM
    CrippledHo
    Eric
    2016 DCSB Diet Coke
    I run the right side 10psi lower than the left to account for the extra weight on the left side.
  11. Feb 5, 2020 at 9:33 AM
    CrispyTacoLover
    lol, exactly.
  12. Feb 5, 2020 at 9:34 AM
    CrispyTacoLover
    You should balance with more hoes. A lot more fun.
    CaptainBart45 likes this.
  13. Feb 5, 2020 at 9:38 AM
    CrippledHo
    Eric
    2016 DCSB Diet Coke
    Would help with balance, but hauling all of those extra hoes around would not help mileage.
  14. Feb 5, 2020 at 9:51 AM
    splitbolt
    NW Arkansas
    Huh...
    I thought the SR5 tire was a P245/75/16/109, which should be 32 psi.
  15. Feb 5, 2020 at 10:18 AM
    #35
    Falcon5Romeo
    Tex
    My door jamb says 29, my tires say max pressure 44. Right now I'm at 38 front, 37 rear.
  16. Feb 5, 2020 at 10:21 AM
    #36
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I agree with this statement.
    I keep mine at the recommended 30psi as per Toyota. I do however run them at 32psi in the winter, as they fluctuate too much due to our climate.
    And my tires are oversized.
    shakerhood and Dagosa[QUOTED] like this.
  17. Feb 5, 2020 at 1:32 PM
    #37
    splitbolt
    NW Arkansas
    What is the size and load rating of the OEM tire?
  18. Feb 5, 2020 at 1:41 PM
    #38
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I roll with 34psi.
  19. Feb 5, 2020 at 1:55 PM
    #39
    JayTRD88
    JayTRD88 Well-Known Member
    Jay
    19 Tacoma TRD Sport
    I had mine at 32 all around but since its winter time, it went low to 29s because of the cold weather. Even if i set it back to 32 chances are it wont stay that way till the weather gets warmer...
  20. Feb 5, 2020 at 2:45 PM
    #40
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    Same here. When the temps get down to single digits and pressure drops a lb every ten degrees, that’s three lbs from 30 to 0 degrees. 32 is a safe compromise.
    Tocamo[QUOTED] likes this.
