Tire Pressure?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Falcon5Romeo, Feb 5, 2020.
  1. Feb 5, 2020 at 3:20 PM
    #41
    ksJoe
    ksJoe Well-Known Member
    Joe
    Kansas
    2020 TRD Off-Road
    Is that like when a girl asks if something makes her look fat?
    Superdave1.0 likes this.
  2. Feb 5, 2020 at 10:56 PM
    #42
    Alnmike
    Alnmike Well-Known Member
    PNW
    '21 4R
    Sorry, can't resist...
    More accurately, a percentage of Pascals drop for every percentage of Kelvins.
    Please don't make me do the math, which would be hilarious if it turns out to be 1psi for 10degF in the exact 10degF range you happen to have measured to get your rule.
    PV=nRT
  3. Feb 6, 2020 at 4:26 AM
    #43
    gargamel05
    gargamel05 Well-Known Member
    Bay Area,CA ---> Easton,PA
    38F/36R is what I run.
  4. Feb 6, 2020 at 4:30 AM
    #44
    nomnomtaco
    nomnomtaco Well-Known Member
    2019 Black Tacoma Limited
    Hot Stock
    I like to max out tire pressure at 88psi. Gets the mpg up.
  5. Feb 6, 2020 at 1:42 PM
    #45
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    And more accurately, the tire pressure is affected by altitude also.
  6. Feb 6, 2020 at 1:45 PM
    #46
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    Ya, I like to take the valve stems out altogether when rock climbing.
  7. Feb 6, 2020 at 11:11 PM
    #47
    Alnmike
    PNW
    '21 4R
    Most accurately, technically it doesn't. :)
    Psia vs Psig.
  8. Feb 6, 2020 at 11:28 PM
    #48
    WhiteTruckMafia
    WhiteTruckMafia Well-Known Member
    TN
    19 TRD PRO
  9. Feb 6, 2020 at 11:32 PM
    #49
    WhiteTruckMafia
    TN
    19 TRD PRO
    Door says 30psi for all 4. Running OEM tires it’s perfectly fine for me. I check psi with a gauge once a month and it’s always dead nuts with my TPMS readings. My garage is temp controlled, so I park the truck outside for a few hours before checking my cold psi.
  10. Feb 7, 2020 at 5:47 AM
    #50
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Psia vs psig is just a unit of measure. One being absolute psi measuring with atmospheric and one measuring psi ignoring atmospheric. Tire pressure gauges measure in psig because atmospheric is already in the tire to start. Therefore an increase in altitude of a tire filled to 32psig at sea level will see a balance of forces change when increasing altitude. This effect is pretty mild though.
    So on the coast the atmosphere is 14.7psi and in Colorado it is 12psi. The change in outside pressure will be -2.7psi. Will the tire just expand a bit to account for the change in force or will the pressure show an increase of internal pressure? I would be interested in knowing that.
  11. Feb 7, 2020 at 10:30 AM
    #51
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    “However, as altitude increases, atmospheric pressure decreases.
    Climbing higher in altitudemeans the air offer less resistance, which creates a higher level of pressure within the tire itself. To keep your tires perfectly balanced, pressure should be adjusted while you are at higher altitudes and again at lower.”
  12. Feb 7, 2020 at 10:38 AM
    #52
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    I belive the actual expansion or stretching of the tire is minimal. But, because the tire is made of different materials in different places in the tire, the shape of the tire is altered which changes the internal volume to accommodate the change in air pressure. This means there will be an actual change in air pressure at different elevations.
    Speedfreak[QUOTED] likes this.
  13. Feb 7, 2020 at 12:32 PM
    #53
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    I run 32psi propane to keep em cool.
  14. Feb 7, 2020 at 1:53 PM
    #54
    Hal_XIII
    Hal_XIII Well-Known Member
    Chicagoland
    19 Tacoma Trd O/R 4x4 S/B 6spd auto cav-blue
    Bilstein shocks & springs. Method 16in wheels Rigid led fogs 265/75 16 BFG KO2s
    I run 35f and 33r on my 265/75/16
    E rated KO2s.
  15. Feb 7, 2020 at 2:05 PM
    #55
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    Good for flaming burnouts too!
  16. Feb 7, 2020 at 2:26 PM
    #56
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Currently at 0 psi because runflats. My tires grip so well on the trail. I also converted to 2wd to improve MPG.
    Speedfreak and CrippledHo like this.
  17. Feb 7, 2020 at 2:28 PM
    #57
    CrippledHo
    CrippledHo I'm calling about your car's extended warranty
    Eric
    Biggest Little Dumpster
    2016 DCSB Diet Coke
    Dents and a rattle can
    I also took out all that needless 4wd stuff and converted the dial to a coffee maker. 4hi for 1 cup, 4 lo for 2.
  18. Feb 7, 2020 at 2:33 PM
    #58
    Superdave1.0
    SoCal
    Legit. I think I'll convert my switch to inflate my blow up doll. I keep her behind the back seat. I'm never alone :thumbsup:.
  19. Feb 7, 2020 at 2:35 PM
    #59
    CrippledHo
    Eric
    2016 DCSB Diet Coke
    Genius. I always kept mine at home, but the new possibility for endless road head is literally blowing my mind.
  20. Feb 7, 2020 at 2:36 PM
    #60
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Carpool lane....:thumbsup:
