Tire pressure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AJ`s Inferno Offroad, Jun 22, 2020.
  1. Jun 23, 2020 at 12:26 PM
    #41
    Sungod
    Sungod Well-Known Member
    St Augustine
    Your truck rides on air. The tires just keep it in place. With steel belts, the tread sits very flat over a very wide range of air pressure. Heat is what causes tire wear and with E range tires, it is the thickness that causes the challenge. Those extra plies don't dissipate heat as well as thinner C tires do. If you are running Es tire wear is kind of a take what you get position. You go low, they get hot. You go high and it rides like a brick. Then again, people are not typically getting Es because they like a Cadillac ride.
