Tire pressure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BackcountryTacoma, Feb 7, 2022.
  1. Feb 7, 2022 at 7:15 AM
    BackcountryTacoma
    BackcountryTacoma [OP] Member
    21’ Trd Pro
    A lotta stuff ;)
    So I like the chalk test for wear on my tires and the alignment check. But has anyone done any actual tire pressure gas mileage per gallon testing. I know too low pressure would be lower mpg but does that mean the max Pressure on the tire would be you the best gas mileage possible? I know there’s a middle ground because of treadwear but does that make sense?
    boston23 likes this.
  2. Feb 7, 2022 at 8:22 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I don’t think anyone is going to waste their time over negligible differences.
    Go collect the data and post it up when you are finished.
  3. Feb 7, 2022 at 8:27 AM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    boston23, shakerhood and Jerry311SD like this.
  4. Feb 7, 2022 at 8:32 AM
    BackcountryTacoma
    21’ Trd Pro
    A lotta stuff ;)
    OZ TRD likes this.
  5. Feb 7, 2022 at 8:39 AM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    Montana_Actual likes this.
  6. Feb 7, 2022 at 8:41 AM
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    The max pressure stated on a tire is just a "suggestion" I run at 85 psi and get the milage of a prius
  7. Feb 7, 2022 at 8:48 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    It's a balancing act, but think 85 is a good working number for anyone interested in getting the best MPG, and isn't overly concerned with ride quality.
  8. Feb 7, 2022 at 8:48 AM
    758_Moto
    758_Moto Well-Known Member
    2004 LT Taco, 2019 Taco
    2019: Icon Coilovers/UCA/AAL, 16x8 Methods/285 Duratracs, URD Spec-U Exhaust, Nexus +P Tune 2004: Chaos LT w/Kings/62" Deavers/12" TC Shackles, Glassworks hood/fenders/bedsides, TRD SC, URD fuel mods/lightweight flywheel/10psi Pulley, JBA Headers, TT Supra MAF
    They always put mine at 32 as well, I bump them up to 35
    TA2016 likes this.
  9. Feb 7, 2022 at 8:56 AM
    eurowner
    eurowner Duke Sky
    Scoty
    His mission is to get 50 post asap.
  10. Feb 7, 2022 at 8:57 AM
    mic_sierra
    Elsewhere
  11. Feb 7, 2022 at 9:02 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Just put in 35 psi for stock tires. It's a good balance between ride, wear and mileage. If you put more in you'll get better mileage but wear your tires out on the inside. If you put less in you'll get a softer ride but wear your tires out on the outsides. Whatever savings you make on mileage or improvement in ride you'll lose on replacing your tires earlier than you could have.
    Cereal_killer and Slick Taco like this.
  12. Feb 7, 2022 at 9:06 AM
    GreenTexasTaco
    GreenTexasTaco Tiny Member
    Texas
    2022 Army Green TRD OR DCLB
    I honestly put 38-40 in my KO2s. Seems like most folks go with less, but I’m getting even wear and ride is nice.
    ORtoCOTaco likes this.
  13. Feb 7, 2022 at 9:22 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I have upsized 265/75/16 (C load) tires, and I keep them at 32psi in the winter, and approx 30-32psi in the summer. I always had upsized tires, and get great wear out of them.
    davidstacoma likes this.
  14. Feb 7, 2022 at 9:24 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
  15. Feb 7, 2022 at 9:26 AM
    BackcountryTacoma
    21’ Trd Pro
    A lotta stuff ;)
    OZ TRD likes this.
  16. Feb 7, 2022 at 9:31 AM
    604
    604 Well-Known Member
    2002 Lincoln Navigator V8
    from 32 to 85? ..... are you trolling? I wouldn't know. does that mean there is a higher chance of getting flat because there is more pressure in there?
  17. Feb 7, 2022 at 9:35 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    If you have stock tires and are inflated to 38 then you are overinflated, the owners manual and the sticker on the door are around 30.
  18. Feb 7, 2022 at 9:47 AM
    sporin
    sporin Well-Known Member
    Dave
    Vermont USA
    '21 Tacoma TRD-Offroad
    At 100psi the truck actually levitates above the roadway. Infinite MPG achieved.
  19. Feb 7, 2022 at 9:52 AM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    If you post a few pictures of your taco, we may be able to assess this better.
    I aim for even wear across the thread - for everyday road use…
    I am currently around 36 at the front and 33 at the rear
  20. Feb 7, 2022 at 9:53 AM
    OZ TRD
    Central Coast CA
    Yes- but then there is the issue of How to produce the “m” in mpg with no traction…:D
    Slick Taco likes this.
