Tire pressure
Discussion in 'Wheels & Tires' started by DesertRatR, Feb 22, 2022.
  1. Feb 22, 2022 at 5:05 PM
    DesertRatR
    DesertRatR [OP] My favorite dog is what I got.
    Southern AZ
    2019 TRD 4WD Off-Road
    I am running +1 K02 tires on a 2019 TRD Off Road. The door post placard pressure is 30 psi. I don't carry cargo, especially off-roading. Would there be any reason to set the pressure at 45 psi?
  2. Feb 22, 2022 at 5:11 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
  3. Feb 22, 2022 at 6:17 PM
    DesertRatR
    Southern AZ
    Yes LTs. I’ve been keeping them about 35 for street. The truck came back after service at 45. No explanation.
  4. Feb 22, 2022 at 6:22 PM
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    45 isn’t too far out of the question.
    These are LT tires and need higher pressures or else the sidewalls will have a lot of stress on them.
    My alignment guy raised mine from 35ish to 42ish and explained to me that you could even go a little higher.
    Truck handles much better and mpgs are a tick better. And only a tad more rough on road feel
  5. Feb 22, 2022 at 6:36 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    45 is way to high, 35 front, 32 rear is more like it. Good ride and traction.
  6. Feb 23, 2022 at 1:38 AM
    jadatis
    jadatis Well-Known Member
    Peter
    For ofroading mayby even 15 psi is enaugh, and on road 20 psi if speed is not to high.
    Let me calculate it for you, give weights on tires and tire specifications.
  7. Feb 23, 2022 at 7:39 AM
    eurowner
    eurowner Duke Sky
    Scoty
    My guess is you are on 265-75-16 size 10ply K02? 45 is too high for a light truck. I went to 265-75-16 SL rated tires and have them at 30psi with flat tread wear on my '17.
    I run my 235-85-16 K02 at 40 psi with this heavy pig and the tire tread wear is flat.
