Tire pressure...
Discussion in 'Wheels & Tires' started by Archaic2021, Jul 6, 2022.
  1. Jul 6, 2022 at 6:34 AM
    Archaic2021
    Archaic2021 [OP] Well-Known Member
    So my set up is dick cpeck wheels 15x8 -19 offset with 30x9.5r15 general grabber atx tiresload range c.
    Been on for about 20k miles. I've noticed that during the last rotation the front outer tread was feathering...I haven't rotated them in about 10 miles.
    I have been having a bad vibration issue around 65mph.
    I upped the tire pressure to 42 and it seemed to help alot but still there kinda...max pressure is 50. Should I go up just a bit more.
  2. Jul 6, 2022 at 6:37 AM
    Bishop84
    Bishop84 Well-Known Member
    Feathering has more to do with alignment and tread style.
    You've basically inflated it until the edges are no longer contacting the road.
    Ideally, you should get your front end checked. Aligned. And a cross diagonal tire rotation.
    Have you ever done ball joints or steering rack bushings?
  3. Jul 6, 2022 at 7:24 AM
    Archaic2021
    Alignment hasnt been done since last summer.
    I have not done ball joints or steering rack bushings.
  4. Jul 6, 2022 at 12:49 PM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    I'd do a rebalance and alignment. Vibration at 65 mph sounds like an out of balance tire to me. 42 psi is pretty high.
    RebleAZ likes this.
  5. Jul 6, 2022 at 12:59 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Somewhere around 35 PSI is plenty. You don't have an air pressure issue. Aggressive cornering will cause feathering. It is more noticeable with wider tires and aggressive tread. Worn shocks will do it too.
  6. Jul 12, 2022 at 7:44 AM
    Archaic2021
    I have new shocks...I have wide wheels not really wide tires.
