tire psi??
Discussion in '4th Gen. Tacomas (2024+)' started by Lionsgaffer, Mar 18, 2025.
  1. Mar 18, 2025 at 6:29 AM
    Lionsgaffer
    Lionsgaffer [OP] Active Member
    Al
    Tacoma v6 trod sport
    Stereo
    Recently got a set of Tundra TRD Pro 18 in forged BBS wheels with Wildpeak 285/65/18 swapped onto my TRD Sport and the app says tires are inflated to anywhere from 43-47 psi now whereas before the app said stock wheelset/tires (MIchelin 265/65/18) were 34. I really like the change so far, but do sense the tires are rock hard. What psi should they be set at???
    Thanks,
  2. Mar 18, 2025 at 6:33 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
  3. Mar 18, 2025 at 6:35 AM
    JB_TN
    JB_TN Well-Known Member
    JB
    Tennessee
    2024 Bronze Oxide TRD OR
    Take a look at the sticker in your door jam and use that as a guide. If need be then do the chalk test.
    synfinatic likes this.
  4. Mar 18, 2025 at 6:42 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Somewhere in the low 30s
  5. Mar 18, 2025 at 7:05 PM
    Lionsgaffer
    Al
    Stereo
    No, thats for the stock tire size, not the current one I just put on per OP.
    Thanks though,
  6. Mar 18, 2025 at 7:12 PM
    Clearwater Bill
    Billy
    Largo Florida
    Doesn't matter. Still a good starting point
    Don't confuse air volume (bigger tires) and air pressure..
    Post 3 works
    JB_TN likes this.
  7. Mar 18, 2025 at 7:26 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    The ideal air pressure will give you even wear across the tire. Follow that pressure calculator for the best attempt to set the air pressure correctly for normal driving. If you load the bed, you will want to increase the air pressure no more than the listed max pressure. As the tire wears you will be able to see the wear pattern and make adjustments accordingly.
    Lionsgaffer[OP] likes this.
  8. Mar 19, 2025 at 8:50 AM
    soupy1234
    soupy1234 Well-Known Member
    2024 Celestial Silver TRD OR LB
    The tool Rock Lobster listed ( ) can advise the correct pressure for your new tires based on the door placard pressure for the originals.
  9. Mar 21, 2025 at 6:07 AM
    TheDanimal
    TheDanimal Well-Known Member
    Daniel
    DFW
    2024 Silver TRD OR 6MT 2019 MBM TRD OR 6MT (RIP)
    Tire pressure is one thing but keep in mind that you went from a highwall all season to an all terrain tire so the Michelin's will obviously have a smoother ride
  10. Mar 21, 2025 at 6:21 AM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Are the Wildpeaks load E ?
    43-47 seems a bit high to me.
  11. Mar 21, 2025 at 6:25 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    It’s really not a good starting point because the new tire is a completely different load range and doesn’t require the same volume of air to maintain its shape.
  12. Mar 21, 2025 at 6:26 AM
    BLtheP
    Plano, TX
    If they’re load E, then you would want to air them to 38 psi to match the stock door sticker pressure of 32 psi.
    If they are SL rated and not LT E, you would want to run them at 29 psi.
  13. Mar 21, 2025 at 6:36 AM
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    There are at least FOUR current versions of "Wildpeaks" in 285/65-18.
    A/T4W = E range
    A/T4W & A/T3W = SL range
    R/T01 = E range
    Gotta be specific. There are no minder readers here.
