Tire question with 3"OME lift, 285/75/16
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeepmor, Mar 8, 2011.
  1. Mar 8, 2011 at 12:33 AM
    jeepmor
    jeepmor [OP] Well-Known Member
    I'll be putting on a 3" OME lift kit soon on my 09 Dbl cab and bumping up to a bigger tire now that the ragged trails are on their wear bars. I'm hoping for 285/75/16 on my stock wheels. I like the stock wheels and will just paint them black. I don't mind a little bit of plastic fender liner trimming and know it's required, but I can't seem to find exactly where to trim after a night or two of browsing TacomaWorld.
    Will the 285/75/16 tire fit on this combo ON the stock wheels or will I need to buy wheels too? What about the TPMS (tire pressure monitoring system) too.
    I'm trying to plan the budget and don't want the 'you need new wheels for that to work' speech without seeing it coming.
    I'd like to use this thread to answer these questions and illustrate where the trimming is required, or at least links to it.
    jeepmor
  2. Mar 8, 2011 at 4:58 AM
    Brunes
    Brunes abides.
    Rotorhead
    There isn't a single way to trim. It changes a bit based on alignment. You should be able to tell pretty quickly where you need to take some more plastic off tho. Take little bits at a time and try it out. Take more off if you need to.
  3. Mar 8, 2011 at 1:06 PM
    House Doc
    House Doc Active Member
    My son's 07 Dbl Cab TRD 2WD had 275-75-16 on it when we bought it used, no rubbing. I put the OME 3" kit on and he is planning on 285's soon. No problem on his truck with clearance.
  4. Mar 8, 2011 at 1:08 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    Subbed........till roughly 20,000 miles from now
  5. Mar 8, 2011 at 1:24 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    The issue is whether you have too much backspacing and the tires will rub the UCAs. If they do the only alternative is new rims or wheel spacers.
    Here's the longest tire fitment thread in the universe. You may find the answer here.
    http://www.toyotanation.com/forum/showthread.php?t=184562
  6. Mar 8, 2011 at 1:50 PM
    2009tacoma
    2009tacoma Member
    RJ
    northern california
    09 4x4 SR5 TRD offroad
    3'' leveling kit, prerunner bumper, 33'' Big o XT Tires, K&N, Rock Sliders, Rear Locker, three 5'' procomp lights on bumper
    i have a 2009 and i have a 3in leveling kit and im running 285/75 16 with stock rims i had to get 2.5in wheel spacers because the tire was rubbing on the upper control arm at full turn
  7. Mar 9, 2011 at 12:42 PM
    jeepmor
    Is that 2.5" per wheel or total backspace.
    To clarify, I interpret your response as a total backspacing of 5 inches of additional track width, not. 2.5". Is this correct?
    Just trying to clarify before I start ordering stuff.
    Thanks for the help.
    Jeepmor
  8. Mar 9, 2011 at 12:48 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
  9. Mar 9, 2011 at 12:49 PM
    BUB_IROC_Z
    BUB_IROC_Z Well-Known Member
    Anthony
    North Eastern Ohio
    2010 4x4 4.0 Taco
    3 inch OME, Rear diff breather mod, Aeroforce Interceptor Gauge and custom gauge pod, Yellow Wire Mod, Avid Off-road bar, Bud built Skid Plates,
    I have an OME 3 in lift on my truck with 285/75/16. I bought new rims and tires at the same time. They rub a little when I have the wheel cocked all the way to the right or left. You shouldn't have any problems with the stock rims. If they do rub a nice set of wheel spacers should fix it no problem.
  10. Mar 9, 2011 at 1:23 PM
    jeepmor
    Figured 2.5 was it, 5" of additional track width seems a bit obnoxious. Plus, I could not find 2.5" thk spacers.
    How wide are the stock wheels? Anyone know? 285/75/16 spec out a 7.5-9" wheel.
