tire question
Discussion in 'Wheels & Tires' started by jcap311, Jun 6, 2009.
  1. Jun 6, 2009 at 5:42 AM
    jcap311
    jcap311 [OP] New Member
    north nj
    tacoma
    just put on new tires on my 01 tacoma. bf goodrich allterrain t/a ko. these are not stock tires. it calls for 65 psi seems like way to much. on the side of the door truck says 29 psi looks a little low for that. any recomdations for the rigth psi in these tires? and does anybody have any experiance with these tires thanks
  2. Jun 6, 2009 at 5:44 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    set then at 32psi :D
  3. Jun 6, 2009 at 5:53 AM
    98tacoma27
    Ben
    Not Beech Creek
  4. Jun 6, 2009 at 5:57 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    +1 on the chalk test. The 65 psi on the tire is the MAX. The 29 psi on the door is the recommended tire pressure (for comfort and fuel economy) on the stock size/model of tires only.
    Using that chalk test will give you an ideal wear pattern- From there you can adjust them for comfort or mpgs.
