Tire question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by caleb donnellan, May 12, 2016.
  1. May 12, 2016 at 4:10 PM
    caleb donnellan
    caleb donnellan [OP] Well-Known Member
    Caleb
    West Virginia
    2022 Lunar Rock TRD Off Road
    2022 Lunar Rock TRD Off Road Stock for now
    I have the fj trd trail team wheels and a three inch toytec lift I just ordered duratracs in a 265/75/16 but was curious if a 255/85r/16 would rub a lot with the wheels I have and the three inch lift
  2. May 12, 2016 at 4:14 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
  3. May 12, 2016 at 6:46 PM
    Pigpen
    Dan
    Northwest Montana
    Mine rub a little. Little enough to be acceptable. I haven't had to trim anything, FYI
  4. Jun 15, 2016 at 12:10 PM
    dub_11
    dub_11 Active Member
    Jacob
    Alberta, Canada
    2011 Red Tacoma Access Cab
    3" Pro Comp Lift Kit 285-70R17 Federal Cougaria M/T 17x9 Pro Comp Extreme Rims
    i have 33's had to take front mud flaps off but besides that no rubbing !
  5. Jun 15, 2016 at 3:08 PM
    GroupW
    GroupW Well-Known Member
    Mark
    Arizona
    Red TX
    3 inch lift with Toytec Boss and All Pro UCA's up front. AP expedition leafs with Bilstien 5100 shocks in the back. 255/85/16 Cooper S/T Max tires. All Pro skids, rear bumper and sliders, Hidden winch mount with XRC 8000 winch. Dual Optima batteries with IBS combiner/isolator and solar. CMC. Auto sliding rear window mod, hidden CB, CVJ axles and plenty of other little mods.
    I have 255/85's with a 3 inch lift. No big deal for a mall crawler, but they will rub off road - best to go for the cab mount chop and bash the pinch weld.
    DustStorm4x4 likes this.
