Tire Question
Discussion in 'Wheels & Tires' started by taco2408, Aug 27, 2009.
  1. Aug 27, 2009 at 6:30 AM
    taco2408
    taco2408 [OP] Well-Known Member
    Marcos
    San Antonio, TX
    08 PreRunner DoubleCab
    Ok, I have a 2008 PreRunner DoubleCab 2wd. It's the base model and does not have a lift. I just bought new wheels (Moto Metal 955 black) and new tires (BFG A/T 265-75-16). After searching on this forum I thought that these were the biggest tires that I could fit on my truck without any rubbing. Well, I was wondering why these tires were rubbing a little on the mud flap and the plastic in the front of my truck. Does this have to do with the Moto Metal wheel? The other option I had was going with the 265-70-16 but these tires look like they are basically the same size as the 245-75-16 that is already on there. I'm going to stick with the bigger size and just remove the mud flap. But I was wondering if anyone else had that problem? Thanks.
  2. Aug 27, 2009 at 6:38 AM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    yes this has to do with the wider wheels. if the 265/75's were on stock wheels they wouldn't rub at all. oh by the way, lets see some pics of the new kicks and wheels
  3. Aug 27, 2009 at 8:03 AM
    taco2408
    Marcos
    San Antonio, TX
    the new wheels are 16x8..what size are stock wheels??..So this size tire is okay on my truck and won't damage anything...also I will post some pics this afternoon..I really like the new look
  4. Aug 27, 2009 at 8:34 AM
    gupster88
    Brett
    Almost Heaven, WV
    Stock
    stock wheels are 17x7.5 i do believe. not sure what your backspacing is with the 955's but mine is 4.5 compared to 5.5 stock so all in all my wheels stick out an extra 2.5". should be fine though. might "feel" the road more than you did stock.
  5. Aug 27, 2009 at 8:39 AM
    taco2408
    Marcos
    San Antonio, TX
    thanks for the help..i try and post some pics and let me know what you think
  6. Aug 27, 2009 at 8:40 AM
    gupster88
    Brett
    Almost Heaven, WV
    Stock
    ok sounds good!
