Tire question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beerline123, May 29, 2022.
  1. May 29, 2022 at 9:20 PM
    Beerline123
    Beerline123 [OP] Well-Known Member
    07 Tacoma access 4x4
    Moneys been very tight last few years and I had bought 4 tires off Craigslist. Definitely not top of the line by no means starfire 510 2 of which have a lot of life left in them and 2 that won't pass inspection.it looks like they may be discontinued so my question is can I buy 2 tires of different brand with similar tread pattern used on the same axle without damaging transmission or transfer case. Tia
  2. May 29, 2022 at 9:35 PM
    hxp05560
    hxp05560 Well-Known Member
    2009 TRD Off-Road
    TRD Pro Wheels - Duratracs Black Softopper
    I wouldn’t recommend it. Your tires are going to wear differently, shortening their life and causing more issues down the road. If you can run two of the same tires on each axle, having two sets of two tires. Lord knows I’ve been where you are so I can definitely relate! I had a Chevy S-10 for over ten years and had to do the same thing on several occasions. I never had issues buying tire pairs.
    I’m not sure if you’ve looked into it, but sometimes the small, family owned tire shops will sell used tires with low miles on them at steep discounts. The bigger chains won’t do this for liability reasons. Of course you’ll forfeit any warranty, but tires from Craigslist don’t have that anyway.
    All the best! :cheers:
    Thatbassguy likes this.
  3. May 29, 2022 at 9:35 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Not if you plan on engaging the 4x4.
    Tires should be of the same relative treadwear.
    In practice, anyhow. In reality, fronts and rears will always have some scrub (rotational difference). They'll just have more scrub if they're not similar.
  4. May 30, 2022 at 11:11 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    You safely install any type tire on same axle as long as they are the same outside diameter. There is some leeway there also; otherwise, you would blow the axle with differing tire pressures.
    Alexely999 and eating raoul like this.
  5. May 30, 2022 at 11:31 AM
    eating raoul
    eating raoul I miss lockout hubs!
    New Mexico
    2018 Tacoma TRD 4x4.... and a 1987 4x4 pickup
    None on the 2018, 35 years of hard wear on the 1987
    As long as the size is the same you shouldn't have a problem. I used to have to do this all the time when I was young and poor(er).
    Laying rubber and similar heavy foot practices are what does the damage.
  6. May 30, 2022 at 12:05 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Yes. If they’re the same size you’ll be fine. Ie: if to have 265/65/17s on the front and need two rears just buy the same size.
  7. Jun 2, 2022 at 11:16 AM
    Beerline123
    Thanks guy's still makes me anxious but the parent company Cooper tires said their solarus tire is the replacement for the 510 so I'll give it a shot. Trucks got to last me but thank God she still rides great at 174,000 . good day to all
