Tire Question??
Discussion in 'Wheels & Tires' started by Manwithoutaplan, Feb 25, 2010.
  1. Feb 25, 2010 at 9:16 AM
    Manwithoutaplan
    Manwithoutaplan [OP] the full Monty
    ID
    I have question about tires. IF i am currently running 315/70/17 on a 8 inch rim. WOuld i be able to run a 35/12.50/17 BFG KM2 tire on the same rim.
  2. Feb 25, 2010 at 9:24 AM
    98tacoma27
    Ben
    Not Beech Creek
  3. Feb 25, 2010 at 9:26 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
  4. Feb 25, 2010 at 9:28 AM
    ST77
    ST77 Wandering doesn't mean you're lost
    Brian
    Sandy, Or
    2018 TRD OR DCSB
    Bone Stock
    I would think that you would need a 10in rim at min...
  5. Feb 25, 2010 at 9:29 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    General rule of thumb is the tire can be up to 2" wider or narrower than the rim.
  6. Feb 25, 2010 at 9:31 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    Many people run X12.5's on 8" wide rims. I had a Bronco that I ran 35x12.5 mudders on 15x10 rims but many ran them on 15x8 rims. Some even recommended the narrower rim because the tire bead held more pressure against the rim when aired down for wheeling. Some also claim the sidewalls being pulled in more prevent side puncture too. To be fair, there are many arguments against the narrow rims too. One drawback to the narrower rim is uneven wear. It is hard to get the tread flat on the ground with the sides being pulled in so much.
  7. Feb 25, 2010 at 9:38 AM
    Rhino8541
    Rhino8541 I like ze best!
    WA
    2017 QS DCSB OR
    Pretty sure 315/70/17 is the same size as 35/12.5/17, so it should run just the same as your current tires. There are differences between manufacturers though. I also would advise a wider tire, many are available in 9" wide, which falls in the 8.5-11" range.
