Tire question
Discussion in '1st Gen. Tacomas (1995-2004)' started by ghack, Sep 29, 2022.
  1. Sep 29, 2022 at 5:49 PM
    ghack
    ghack [OP] Member
    2003 tacoma
    i have an 03 Tacoma with 265/70R 16 tires on it that need to be replaced. What other size tires can be used on those rims. I'm having trouble finding used tires that are the same size.
  2. Sep 29, 2022 at 6:31 PM
    Twheatley
    Twheatley Member
    Tim
    Looking a 1st Gen Double Cab 4x4
    The 265/70/16 is a pretty common tire size.... There's a few sizes you could go.
    245/75/16
    265/75/16
    There is a Tire Size Calculator on the interwebs somewhere and you can punch in your current tire and other tire sizes and see the difference.
    Hope that helps!
  3. Sep 29, 2022 at 6:39 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    You should able to find takeoffs at a dealer and on TW.
  4. Sep 29, 2022 at 6:40 PM
    Twheatley
    Twheatley Member
    Tim
    This!
    Dealers can get takeoffs from Toyota Complete Maintenance Care Website.
  5. Sep 30, 2022 at 7:32 AM
    ghack
    ghack [OP] Member
    2003 tacoma
    Thanks, I found someone with 245/70 16’s mounted on Toyota 6 lug rims, but I wasn’t sure if those rims would be different width.
  6. Sep 30, 2022 at 7:53 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Make sure they are 1st gen taco/3rd gen 4runner 16" wheels. Backspacing is different on the later gens and you'll encounter frame rub at full lock when turning.
