Tire Recommendation for Road Trip
Discussion in 'Wheels & Tires' started by SOLID, Feb 8, 2021.
  1. Feb 8, 2021 at 6:36 AM
    SOLID
    SOLID [OP] Well-Known Member
    Jamie
    Louisiana
    2017 Magnetic Gray Tacoma TRD Off Road
    265/70R16 Duratracs SPC 25470 Upper Control Arms Old Man Emu 90021-P Nitrocharger Sport Front Shocks Old Man Emu 887 coils Old Man Emu 60091-P Nitrocharger Sport Rear Shocks Old Man Emu EL119-P Leaf Springs Old man Emu Carrier Bearing Drop Cali Raised Kick Out Rock Sliders Goose Gear Rear Seat Delete WeBoost Signal Booster Switch Pro SP9100 8-Switch Panel Power System Vertical Switch Pro PowerTray with install kit Cali Raised Off Road Switch Pro Mounting Panel upTOP Overland | 38" Dual Function Light Bar Baja Design rock lights - w/ scenePOD 2.0 - 4 - Roof Rack - Bed lighting - 2 - ground - frame - 6 UpTop Bravo Roof Rack UpTop Truss MID Height Bed Rack Mountain Hatch Tailgate Insert Cali Raised LED - Bed Channel Supports 23Zero RTT - Breezeway 62 with LST 23Zero Canopy Condition 1 Case - Roof mount WaterPORT 3.8-gallon self-pressurized water tank Joolca HOTTAP camp shower system Desert Does It Seat Jackers - 2 Desert Does it Front Multi Mount Panel Element fire extinguisher Hi Lift Jack Hondo Garage Un-Holey Phone Mounts - 2
    I'll be taking a spring road trip that will involve 2,000 miles + of highway driving in my stock 3rd Gen TRD OR. I'm hoping to do some moderately aggressive roads like Black Gap in Big Bend National Park. What tires would you recommend that will be reasonable on the highway as well as sharp, stony trails?
  2. Feb 8, 2021 at 8:42 AM
    Tacospike
    Two Trucks
    @Interbeing
    Any recommendations? Seems like a similar trip you take. I forget what you set up you run??
    whatstcp and SOLID[OP] like this.
  3. Feb 8, 2021 at 1:54 PM
    DSRunner
    DSRunner Well-Known Member
    I don't think you can go wrong with BFG KO2's or Falken Wildpeaks. I ran KO2's for my road trip which did great on the highway as well as on trails. Make sure you get at least the Load C ratings.
    SOLID[OP] likes this.
  4. Feb 8, 2021 at 2:07 PM
    SOLID
    Jamie
    Louisiana
    DSRunner likes this.
  5. Feb 8, 2021 at 2:12 PM
    Shellshock
    Iowa
    Falken AT3w. mine have taken me all over the country on and off road.
  6. Feb 10, 2021 at 1:34 PM
    Gswain
    Gswain Eastern sierra living
    If you want something a little more agressive i liked my st maxx coopers, very flat resistant and still good manners.
  7. Feb 10, 2021 at 1:42 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I'll add another data point to the Falken AT3. Good traction on loose rock and comfortable on highway. Those tires got me through a couple of mountains on a surprise late spring snow.
  8. Feb 10, 2021 at 1:46 PM
    SOLID
    Jamie
    Louisiana
    That's good to know. Around here (South Louisiana) there's lots of advice for mud, snow/loose rock....not so much. I appreciate the feedback!
    Rock Lobster[QUOTED] likes this.
  9. Feb 25, 2021 at 11:40 AM
    SOLID
    Jamie
    Louisiana
    Looks like I'll be getting Goodyear Wrangler DuraTrac - 265/70R16 112S installed on Tuesday. Looks like these should be a reasonable, slightly boring solution for the 95% highway / 5% trails I'll be covering. I appreciate everyone's help. Thanks!
