Tire recommendations? P265/70R16
Discussion in '1st Gen. Tacomas (1995-2004)' started by donut, Oct 1, 2022.
  1. Oct 1, 2022 at 10:03 AM
    donut
    donut [OP] Well-Known Member
    Bought the truck with a new set of Goodyear Wrangler SR/As - now with 6k miles already & down to 8/32 (read this was an issue widely reported & this model is now discontinued)
    Recently, found the spare low on tire pressure. Alas the spare was an original from 2004 and needs immediate replacement.
    Looking to buy a new spare that will be around in hopefully a year/18 months when I need to buy a new set. (the spare becomes one of the new set and hopefully 1 of the SR/As is good enough to become the spare) Hope this rational makes sense.
    In the past, Ive always tried to find white lettered/aggressive, but open to any good in snow, aggressive tire.
    Recommendations appreciated. Thank you
  2. Oct 1, 2022 at 10:14 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    There are more options in 265/75/16 and they usually cost less than 265/70/16. They are just a hair taller, same width, but should fit your truck with no problems. Consider that size.
    I'd make the spare work until you buy new tires. But many tire shops will have a decent tire that they have taken off and will sell it cheap. The spare on my 2007 was 15 years old and I found a 4 year old take off with usable tread. I paid $30 for the tire and to get it mounted. I didn't want to use one of my take-offs since they were still usable. I sold them as a set of 4 to help offset the cost of my new tires.
    There are a lot of good choices for the exact tire. Not saying this is "Best", but it is what I put on my Tacoma. This is the most aggressive tire I've found in a non-LT rating.
    Goodyear Wrangler UltraTerrain AT | Discount Tire
    donut[OP] and Rapid Dog like this.
  3. Oct 1, 2022 at 8:51 PM
    Hamer95USA
    Hamer95USA Well-Known Member
    1999 Toyota Tacoma 4x4 SR5 extended cab reborn!
    Complete OME suspension kit, Used low mileage V6 engine swap, black powder coated Chou Seiki T15x7JJ, ARB deluxe bumper, Smitty Bilt nerf bars, Weathertech floor liners, Torklift tiedowns
    I have a set of Cooper AT/3 load E range tires installed on OEM Chou Seiki 16"x7" 4Runner wheels.
  4. Oct 2, 2022 at 1:35 PM
    donut
    Area51Runner likes this.
  5. Oct 2, 2022 at 2:16 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    If I hadn't gone with the Coopers I would have went with the Toyo OCs.
    When you do decide to do tires, when they're being installed ask the installer to swap one of your wranglers on to the spare. Unless you've already replaced by then.
