TIRE REPAIR ITEMS NEEDED FOR 2019 TRD PRO WITH CAMPER
Discussion in '3rd Gen. Tacomas (2016-2023)' started by drbeemer73, Oct 30, 2019.
  1. Oct 30, 2019 at 5:59 PM
    drbeemer73
    drbeemer73 [OP] "Toyota Aterra", see YouTube
    Mac
    Glenmoore, PA
    2019 Tacoma TRD Off Road.
    Heavily modified with very light camper (weighs less than 600 lbs.), off road suspension, rear frame professionally upgraded, F/R bumpers, winch, camper heater, water, double bed, storage behind front seats, etc.
    I have a 2019 TRD Off Road with a *very light* camper being built on a custom cradle. I plan on going to remote places and will rely on myself so I must be prepared.
    Here are the items I plan on carrying so I can repair any tire puncture or rip:
    Items with a * I have on hand, items in bold I have not ordered or I am not sure I will need, IOW they are TBD.
    Tire/tube repair: Note: My tires are E rated, so very tough; Dick Depek Extreme Country, only 46 pounds each
    *Hummer jack (yes army) to jack under axle points so axle raises tire off ground
    *On board air compressor, constant duty, by Extreme Outback, Endura
    *sidewall/tube patches by Taitec TNRE (4.53” by 2.95”)
    EPDM pond liner from David (a friend)
    Safety Seal tire repair kit?
    *sewing awl
    *Spectra sewing line (from Lancaster Archery Supply, PA), to sew sidewall back together
    *stitching wheel
    *scuffing bar
    *vulcanizing cement-small tubes
    *4 oz. can (it dries out "too soon")
    extra tube
    *battery powered drill by Milwaukee, 18 volt, with quick charger
    *drill bit assortment
    *three 27” titanium tire irons
    *2 Bead Pro bead breakers
    * 4-way valve tool
    *4 snap in tire valves
    *1 screw in tire valve
    *valve finishing tool
    *4 valve cores, *4 valve caps
    *30-4 inch tire repair “inserts/strings”
    *rubber lube by Ru Glyde
    2 ratchet straps for beading tire on rim
    All suggestions to make this list better are appreciated, thank you. And certainly, steal this list for your own purposes or another :)
  2. Oct 30, 2019 at 6:01 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    What's the pond liner for? Work cover?
  3. Oct 30, 2019 at 6:33 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Perhaps carry a spare tire?
    whatstcp, Shellshock and kahanabob like this.
  4. Oct 30, 2019 at 6:46 PM
    drbeemer73
    Mac
    Glenmoore, PA
    Skydvrr:pond liner I will get some from a friend, it is the material used to create and line a pond and is VERY tough, so carried in this case if I need to sew a rip in a tire back together.
    Whatstcp: All good input, thanks.
    Cudgel: Spare tire too bulky & heavy, instead I have E rated tires (much tougher than the stock ones) and hopefully ALL the means to repair most any tire problem.
  5. Oct 31, 2019 at 7:09 PM
    drbeemer73
    Mac
    Glenmoore, PA
    Cudgel: Correction, sorry for the confusion, I do have a spare, it will be stored between the cab and the camper, on a cradle built for the camper to sit on.
    whatstcp and Cudgel like this.
