tire/rim size
Discussion in 'Wheels & Tires' started by laynelee23, May 26, 2017.
  1. May 26, 2017 at 4:09 AM
    laynelee23
    laynelee23 [OP] New Member
    2008 Toyo Tacoma prerunner
    i have p265 70r16 currently on my truck im wanting to change to 18rims and tires...the truck is the sr5 prerunner if that makes a difference...but am i going to need to put a lift kit on their in order to change to these rims and tires...?? i dont want to screw anything up...thanks
    ChadsPride likes this.
  2. May 26, 2017 at 4:13 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    First off, welcome to TW. Wheel size doesn't matter as long as the overall diameter stays the same. You could jump to 265/60r18 and that'd be the same diameter. Or you could go 265/65r18 and that'd be +1" over stock, which people run on here. At most you'd have to remove mudflaps to avoid rubbing.
    laynelee23[OP] and ChadsPride like this.
  3. May 26, 2017 at 6:15 AM
    laynelee23
    cool thanks
