Tire Road Noise 285vs255
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Anchovy, Nov 11, 2022.
  1. Nov 11, 2022 at 12:32 PM
    Anchovy
    Anchovy [OP] Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    For anybody who's had both 285/75R16 and 255/80R17 (I think that's right?). Which tire size had more road noise? Or were they the same?
  2. Nov 11, 2022 at 12:40 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    It all depends on your tire.
    hiPSI and drizzoh like this.
  3. Nov 11, 2022 at 12:44 PM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    285/75R16 makes way less noise than 255/80R17, but only if you run the white text on the outside. If you run the white text on the inside, they'll make more noise. Especially on Fridays.
    TS4x4, hiPSI, Wulf and 3 others like this.
  4. Nov 11, 2022 at 12:45 PM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Dammit I’m new to the 3rd gen section!
    Happy Friday!
    Mark77 and 71tattooguy like this.
  5. Nov 11, 2022 at 12:53 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Tread design is the factor. Mud terrain-nosier, Hwy-quieter, All terrain-in between. My 285/75/17 KO2's are very quiet, do not hear in cab.
    Evostaco likes this.
  6. Nov 11, 2022 at 1:05 PM
    Anchovy
    TRD Ferguson
    My question is real. My current 285s make a shit ton of noise above 50. My tires are almost due for replacement and I'm deciding on 285 or 255
  7. Nov 11, 2022 at 1:05 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Tread design is much more important than tire width. But IME width does factor in. When new there is probably little difference, but all tires get louder as they get older and the tread wears down. The wear is less consistent, with wider tires you get high and low spots in the tread, especially on the edges. It is the uneven wear that causes the noise.
  8. Nov 11, 2022 at 1:06 PM
    Anchovy
    TRD Ferguson
    I have cooper ST Maxxs now. I don't remember how loud or quiet they were when j first got them, but now that they have 60,000 miles on them they're pretty noisy
  9. Nov 11, 2022 at 1:09 PM
    Anchovy
    TRD Ferguson
    I remember seeing a chart of the different tire wear and their causes. Isn't the outer edge fluttering caused by bad balancing?
  10. Nov 11, 2022 at 1:09 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    There are lots of good reasons to go 255/85 instead of 285/75.
    i found my st maxx to be really very quiet considering the open tread pattern.
    Pwl and 71tattooguy like this.
  11. Nov 11, 2022 at 1:10 PM
    Anchovy
    TRD Ferguson
    I'm sure there are, but if I did that I'd have to buy new wheels. I'm just weighing my options here
  12. Nov 11, 2022 at 1:11 PM
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    you have really wide after-market wheels?
  13. Nov 11, 2022 at 1:31 PM
    Anchovy
    TRD Ferguson
    No, I'm not a twat. Just regular 16x8
  14. Nov 11, 2022 at 2:07 PM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    I think your rotating them too often?
  15. Nov 11, 2022 at 2:21 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Worn tires make a lot more noise than new tires. Tread pattern is the noisemaker, not the width.
    However, if tread pattern and wear is exactly the same, skinny makes less noise than wide.
    71tattooguy likes this.
  16. Nov 11, 2022 at 2:23 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    Just get a loud exhaust, problem solved.
    71tattooguy and Jeffch like this.
  17. Nov 11, 2022 at 2:55 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Turn up the music :headbang:
    hiPSI likes this.
  18. Nov 11, 2022 at 3:25 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    285 will be louder than a 255, as it has more road contact. Assuming your talking the same tire brand and make.
  19. Nov 11, 2022 at 3:25 PM
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    So why, not being a twat, couldn’t you run 255/85r16? (Instead of 255/80r17 that you mentioned for some reason)
  20. Nov 11, 2022 at 3:59 PM
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    What tires?
