Tire rotation after flipping white lettering in
Discussion in 'Wheels & Tires' started by Enigmaaron, Mar 30, 2011.
  1. Mar 30, 2011 at 6:53 AM
    Enigmaaron
    Enigmaaron [OP] All your soul are belong to us
    PA
    1st gen superiority
    I have a slightly different tire rotation question for you guys. I recently switched from the stock alloys to some black wheels and consequently had the tires flipped around so the white lettering is on the inside now. I think a rotation is definitely in order at this point (and it's close enough to when they should be rotated anyway). The question is which way?
    I'm leaning toward criss cross since that will result in the tire rolling in the same direction as it was previously. Essentially the end result is a front to back rotation like the manual states but the tires are on opposite sides since they were flipped around.
    Or do I just do front to back like the manual states regardless?
    I think in writing this out I've convinced myself criss cross is the way to go but what do you guys think?
  2. Mar 30, 2011 at 6:57 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
  3. Mar 30, 2011 at 7:01 AM
    Enigmaaron
    PA
    1st gen superiority
    I think you missed the point of the question. The tires have been turned around in place therefor standard rotation patterns do not apply.
  4. Mar 30, 2011 at 7:19 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    maybe but you made it sound all crazy in your first post or maybe its just too early for me but do yourself the chalk test make sure everything is good and run them for a while and if you feel the need to rotate them then do what Lrgrnr said.
    if you still so concerned about them just toss the fronts on the back via standard rotation procedures and call it good.
  5. Mar 30, 2011 at 7:21 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    you also might have missed the point of a tire rotation in the first place as well, you rotate them cause your front tires get uneven wear from the left and right turning and you prolong the life by tossing the rears up front. just remounting your tires black out wont make much of a difference in the wear in that perspective cause your fronts are still in front.. assuming that they put your tires on the same corners they came off of
  6. Mar 30, 2011 at 7:22 AM
    Enigmaaron
    PA
    1st gen superiority
    Probably a little crazy, I have a habit of way over thinking things. I'm not really that concerned about it, just wondering what you guys think.
  7. Mar 30, 2011 at 7:23 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    if it gives you peace of mind i would go ahead with the rotation and just keep an eye on the wear patterns and you will be good to go
  8. Mar 30, 2011 at 7:37 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I think you're overcomplicating this. If they're directional tires, they should have put them on the other side of the truck when they put the white letters in meaning your tire rotation pattern wouldn't change... Just rotate them front to back, the side of the tire that the white lettering is on does not affect tire rotation if they were mounted correctly to begin with.
  9. Mar 30, 2011 at 7:51 AM
    Enigmaaron
    PA
    1st gen superiority
    Nah, they aren't directional. I had heard that it's a good idea to keep tires rolling in the same direction through their lifetime regardless and that's why the manual says to rotate front to back. :notsure: That's really the basis of my question.
    Anyway I guess fundamentally the question is just the same old concept of whether to rotate front back or criss cross.
  10. Mar 30, 2011 at 7:56 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    lol its cool what tires are you running anyways?
  11. Mar 30, 2011 at 7:56 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    For me....I rotate the tires front to back - and back to front and always on the same side, every 5K miles.
    This method (for me) is far easier & faster and won't matter what type of tires you're running.
  12. Mar 30, 2011 at 7:58 AM
    Pugga
    Massachusetts
    I just rotate them front to back on the same side. No issues and usually get nice, even wear for the life of the tires.
  13. Mar 30, 2011 at 8:03 AM
    Enigmaaron
    PA
    1st gen superiority
    They are 265/75r16 Firestone Destination AT's. Good tires for my mostly onroad driving. I miss the Cooper Discoverer STT's I had on there before. Looked sick and I could drive through just about anything, but they started getting too noisy for my liking.
  14. Mar 30, 2011 at 8:08 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    i had those when i bought my truck they were alright, you should definitely look into some new tires and make your truck look beefier with a more aggressive tire and not worry about the rotation :D
  15. Mar 30, 2011 at 8:14 AM
    Enigmaaron
    PA
    1st gen superiority
    Haha, that's what I did with the Cooper's and they didn't last long. Unfortunately these tires are only a little over a year old with plenty of tread left. I've thought of trying to sell them though so I can get Duratracs or something.
  16. Mar 30, 2011 at 8:17 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    i have BFG ATs and i like them alot more aggressive than the firestones and quiet and generally good performance but im thinking about selling them cause i really really really wanna get me some red letter general grabbers
  17. Mar 30, 2011 at 9:18 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I always keep the tire rotation direction the same.
    This is 'old school' thinking that originates from early radial tire design. When radial tires first came out there were problems of tread separation when the rolling direction was changed (i.e. cross rotations). I have read and heard that this is less of an issue nowadays with current tire designs.
    When I asked about it at Discount Tire recently, they indicated they still recommend keeping the rolling direction of the tire the same throughout its lifetime.
  18. Mar 30, 2011 at 10:26 AM
    Enigmaaron
    PA
    1st gen superiority
    Ah, that makes sense. Thanks for the info.
  19. Apr 2, 2011 at 3:04 PM
    bivey
    bivey Well-Known Member
    I rotate mine 1st front to back, 2nd cross cross, 3rd front to back, 4th cross cross and so on. I rotate my customers front to rear unless they tell me different.
