Tire Rotation of 5 Tires
Discussion in 'Wheels & Tires' started by chadnick, Jun 17, 2022.
  1. Jun 17, 2022 at 7:45 AM
    chadnick
    chadnick [OP] Member
    When you rotate your tires, do you include the full size spare in the mix? Why or why not?
    I see a lot of trucks/jeeps that look like their spare tire has never seen the ground. Maybe there is a reason for this?
    My assumption is that if you have it, why not use it? Instead of letting it bake in the sun or go to waste when you decide to change tire sizes completely. You also gain 20% tire usage time between replacements due to using 5 tires, instead of 4.
    Supposedly tires have a service life, whether there is tread left or not, they should be cycled out after a certain amount of time. Personally, I have never done this though. After I implemented the 303 Aerospace Protectant tire care routine, I have never seen my tires "wear out" before the tread. Random link about it.
    Curious what everyone does. Thanks
  2. Jun 17, 2022 at 7:48 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Gen dependent.
    3rd gen does not have TPMS in the spare. 2nd gen does.
  3. Jun 17, 2022 at 7:51 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    will the 3rd gen accept a 5th sensor if you add it to the tire and program it in? I'm guessing not, but not sure. If not, I would then say it's not worth it to rotate the spare in if you have to reprogram what 4 sensors the TPMS talks to every time you do a rotation.
  4. Jun 17, 2022 at 8:07 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Unfortunately no. The truck will only accept four sensors at a time.
    BLtheP[QUOTED] likes this.
  5. Jun 17, 2022 at 8:09 AM
    BLtheP
    Plano, TX
    Thanks, good enough for me. I would add one if it would accept it but I am perfectly happy with it not. Just means one less spare for me to feel the need to buy and deal with regularly.
  6. Jun 17, 2022 at 8:12 AM
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    I have a full size spare and matching wheel and rotate it in with the other 4. My local discount tire will reprogram the 5th TPMS sensor and add it to the computer for free if I have them do the rotation. If I do the rotation myself I know that one of my tires will not show up on the TPMS. Not the end of the world and it means I check the pressure manually.
  7. Jun 17, 2022 at 1:24 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    You dont gain 20% more life. The tire is rated for x # of miles whether that takes 4 years or 6 years. And at 6 they should be replaced regardless of mileage.
  8. Jun 17, 2022 at 1:36 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    How much sunlight they get determines how long they last. Six years in Texas may be about right if the truck is not garaged. In an area that gets less sunlight, especially if the truck is garaged or parked in a shady area might get you 10 years.
    I tried to do a 5 way once years ago on another truck and finally decided it wasn't worth the trouble. I used to do it all of the time when I drove a Jeep Wrangler because all 5 wheels/tires matched and it is easy enough to get to the spare.
    On a my trucks I always keep the best of the 4 tires that were on the ground as my next spare. If the old spare is still like new it can be sold. If not just let the tire store keep it as one of the 4 take-offs. That way I'm also rotating the spare before it gets to 10 years old
