Tire Rotation/TPMS
Discussion in 'Wheels & Tires' started by BRUIN8124, Oct 1, 2012.
  1. Oct 1, 2012 at 8:27 PM
    BRUIN8124
    BRUIN8124 [OP] Well-Known Member
    Mark
    VACATIONLAND
    03 4runner Sport Edition 4WD
    This is my first vehicle with the TPMS. These may be dumb questions but I am going to ask anyways. I am long overdue for a tire rotation.
    Is there anything additional that I need to know/do with the TPMS when rotating the tires?
    Is the front-back tire rotation pattern sufficent for our trucks? That is what the Owner's Manual suggested. I just wnated to make sure.
    Thanks for your help guys!
  2. Oct 1, 2012 at 8:35 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    No additional action needed. Front-back rotation is fine. The Tacoma's front and rear tire pressures are close enough that you typically don't need to reset the TPMS system.
    Some of the fancier cars show numerical tire pressure in the trip computer and distinguish each tire's location on the car (front left, front right, etc.). For those cars, if the owner is anal about it, after tire rotation, the TPMS computer should be reprogrammed to register each tire's new position. The Tacoma just shows an idiot light on the dash when one of the tires is low, so it doens't really matter where the tire is.
  3. Oct 1, 2012 at 8:36 PM
    whammond
    whammond Member
    Will
    Eugene, Oregon
    07 DCSB Trd Sport 4wd
    3 Inch Revtek Lift
    For rotations, front to back is usually the best option for mid size trucks. A good tire shop will also rebalance the two tires being reinstalled on the front of the truck.
    Also, from working at a tire store, lots of tire techs are quick to top the air pressure off at 35 psi, when manufacturer actually recommends 28 psi for 2nd Gen Tacomas (correct me if I am wrong).
    As far as TPMS goes, if you check out the owners manual, I believe it states how to reset the sensors after rotations with the little button on the dash under the steering wheel
    Oh yeah! The idiot light will also go on if the damn spare is low!
  4. Oct 1, 2012 at 8:45 PM
    KenLyns
    Belly of the Beast
    If you are running OEM tires, go by the sticker on the doorsill. That sticker is specific to each vehicle trim level. My TRD Off Road sticker says 32 psi for its BFG Rugged Trail tires. Non-TRD trucks with Dunlops may want lower pressure.
    Toyota stopped putting TPMS sensors in the spare starting in 2008. Hey, deleting $30 sensor per vehicle x 120,000 Tacomas a year = extra $3.6 million in Toyota's pocket per year.
  5. Oct 2, 2012 at 12:29 AM
    BRUIN8124
    Mark
    VACATIONLAND
    Awesome, thank you soo much guys!
    +1
  6. Oct 2, 2012 at 12:40 AM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    My 2008 does have the sensor in the spare.
  7. Oct 2, 2012 at 12:56 AM
    DJSPEC
    DJSPEC 808 Zombie Outbreak Tactical Response Team K9 Unit
    Sean G
    Kaimuki,Hawaii
    2011 TRD Sport DCSB 4x4 & 2014 TRD SPORT DCSB & 2016 TRD-OR AC 4x4
    debadged Viper Alarm Diehard Platinum 31M Battery Pelfreybilt Battery Cage OEM roof racks, step sides LED HI/LO Headlights 35W 6000k HID Fog Lights 20% tint Front windows 5% tint rear windows 2 Sets of Rigid Industries D2 above the valance Duallys on Famous Fabrication's Hood Hinge Brackets Rigid Industries SR2 10" in HoodScoop with C4 Fabrications Hood Scoop Bracket Flowmasters Super 44 series 9942446) Dueler A/T REVO2 265/70R17 SCS Stealth 6 Wheels Wet Okole Seat Covers Reese Tow Hitch 33090 Plastidip Front Valance FoglightMod(Fuel Pump Relay Version) Kobalt Slim Tool Box Matt Gecko Truck Bed LED Kit and Sliding Window Security Bar 3" Lift Light Racing Ball-Joint Upper Control Arms (LR8-25470) OME Front Nitro Shock(900021) with 885 Springs OME Nitro Rear Shocks (ARB8-60091) Revtek Add-A-Leaf (REVAALT5B)
    haha my 2011 doesnt have a TPMS in the spare.
  8. Oct 4, 2012 at 9:40 PM
    KenLyns
    Belly of the Beast
    I may be off by a year. The spare sensor may have been deleted in 2009, coinciding with a bunch of other small changes (VSC, LED tail lights, A-Trac for TRD, etc.)
  9. Oct 8, 2012 at 11:36 PM
    D44boy
    D44boy Well-Known Member
    Kaneohe, hawaii
    2011 prerunner double cab
    TPMS sensors can be anywhere on/near the truck. I have all 4 of mine in a tube in the pocket in the bed, and the light stays off.
