tire rotation, why not this way
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ejl923, Feb 8, 2023.
  1. Feb 8, 2023 at 5:40 PM
    #41
    Bishop84
    Bishop84 Well-Known Member
    My point is, if you're crossing to front, cross to the rear. Full send.
    #1 is designed to prevent harshness. #2 has harshness to front and only standard benefit to rear.
    6 gearT444E[QUOTED] likes this.
  2. Feb 8, 2023 at 5:42 PM
    #42
    Williston
    Williston Well-Known Member
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    :rofl:
  3. Feb 8, 2023 at 5:52 PM
    #43
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I have rear wheel drive so this says I should use picture 1 on the left which is what I always used to do back in the day but I do picture 3 on the right because I was told you can't cross rotate anymore - how do I tell which way is correct for me ? Thanks for any replies, details and or links.
    I found this "The C-Metric tire has a directional tread design, while the LT-metric uses a non-directional tread pattern, Michelin - so I guess I can cross rotate - correct ?
  4. Feb 8, 2023 at 5:55 PM
    #44
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    I would still do every 5,000, and do hybrid cross rotation. If your tires wear uneven, 10,000 miles will do a lot more damage. If you rotate at 5,000, and cross rotate so they turn the other direction, then you "erase" that damage by getting back to a smooth surface.
    Say for example your right front wheel wears the most uneven (it typically does because of the cross slope of the road and that tire fights to keep the truck in line... long story...) . If you rotate every 5,000 and cross rotate, then it takes 20k for the first tire to get back to that location, and then again at 40k, but each wheel only 5,000 at that location..
    Typing on my phone here while walking, so I will stop there, but that's the idea.
    Thatbassguy likes this.
  5. Feb 8, 2023 at 6:04 PM
    #45
    Retread21
    Retread21 Member
    Drifter
    South of the Canadian and east of the RioGrande
    2012 4X4 Extended Cab with topper
    So many I forgot and had to make a list, but lost the list
    I salute you ejl923 for starting a thread with a simple question and hoping for good advise but giving some of us a good laugh. Once in a while the children in us comes out to play.
    Seriously, the mileage varies and tire shops like to get repeat business. There is enough B.S. in a tire shop to enrich the entire farm for several years. Just keep watch on your tires and measure the tread as part of normal maintenance.
    As for Costco, I bought new tires and they put them on the back. Buyer's instructions were to put them on the front. My regular mechanic, whom I trust, showed me the factory maintenance manual that directed the new tires be placed on the front. Costco put the tires on the rear so your front tires would take the hit of any road hazards and not the new tires on the front that would cost them. Also watch the technicians as they torque the wheels. When they run them up with the impact wrench, they should need to tighten them with a properly set torque wrench, which should take one or two rotations of the nut. If the torque wrench clicks on the first stroke, the nuts could be over torqued by the impact wrench. I can check that off of the "been there done that" list.
    Again, thank for the lunacy, I needed some relief after four days in a Texas ice storm.
  6. Feb 8, 2023 at 6:05 PM
    #46
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I do actually kinda understand what you were thinking.. first rotation at 5k gets the worn tires switched and then waiting until 10k gets the wear "farther out ahead" of your rotation schedule. I'm following you but it really is overkill. You could try doing it both ways on 2 sets of tires and I'll bet you wouldn't be able to tell a difference in wear after 50k miles.
    That being said I rarely rotate my tires. Lazy, don't really care, whatever.. I switch them out at about 50% tread life anyway because I do a lot of snow driving
    winkel likes this.
  7. Feb 8, 2023 at 6:14 PM
    #47
    Clearwater Bill
    Billy
    Largo Florida
    I let Costco rotate mine for free every 7500. And they let me in the bay to look at my brakes while they balance the tires. But I have to wear my Michelin man outfit.
    I did special rotations on my SCCA car. Soft rubber put on for events, removed after events. :D
    BigCountry762x39 likes this.
  8. Feb 8, 2023 at 6:17 PM
    #48
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    :worthless:
    YF_Ryan likes this.
  9. Feb 8, 2023 at 6:21 PM
    #49
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I do the rotation as image 1 suggests every oil change (8-10k). Getting plenty of life out of the tires.
  10. Feb 8, 2023 at 6:24 PM
    #50
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Nice. I always liked the Torino. Never owned one
  11. Feb 8, 2023 at 6:36 PM
    #51
    Clearwater Bill
    Billy
    Largo Florida
  12. Feb 8, 2023 at 6:39 PM
    #52
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    Whatever route you decide, just make sure you check the work afterwards. You don’t wanna end up with sand in those lug nuts and risk your truck blowing up.
    Steves104x4 likes this.
  13. Feb 8, 2023 at 6:41 PM
    #53
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    I only rotate them if I have to pull 2 of them off.
    Usually buying new tires before they are worn out.
    Currently only have 65K on the truck and I am already on the 3rd set of rims and 4th set of tires.
    Steves104x4 and b_r_o like this.
  14. Feb 8, 2023 at 6:59 PM
    #54
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    I spent enough on five 33" BFG MK3s, so I do a 5 way rotation every 5k miles at the same time I do my oil change and ICON UCA Delta joint lube.
    TOMB, Mully and Thatbassguy like this.
  15. Feb 9, 2023 at 10:06 AM
    #55
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    me too, owned a 1970 Falcon as well which was also a Torino but the "less equiped" model but was it a fun car to drive too, even owned the "last of them" in a 1979 Ford LTD II not near as cool looking
    Steves104x4[QUOTED] likes this.
  16. Feb 9, 2023 at 10:54 AM
    #56
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
  17. Feb 9, 2023 at 11:13 AM
    #57
    BigCountry762x39
    TL
    PNW, Oregon!
    wish id have kept mine, originally was offered it for a set a of used snow tires i got for my mom one year. when i was 15. drove that car to school until my parents found out that i was and parking it behind the school.
  18. Feb 9, 2023 at 11:22 AM
    #58
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    My parents had a black Mk IV with burgundy red leather. Killer car. At least until you tried to go anywhere with it. Literally had to park that thing at the very end of the store parking lot, because if there was another car within a one block radius, those giant-ass doors would bang into it.
  19. Feb 9, 2023 at 11:25 AM
    #59
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    ToyoTaco25[QUOTED] likes this.
  20. Feb 9, 2023 at 11:26 AM
    #60
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Sweet Jesus. I had a ‘72 Sedan De Ville. I parked anywhere I wanted
