tire rotation, why not this way
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ejl923, Feb 8, 2023.
  1. Feb 9, 2023 at 11:27 AM
    #61
    MGMDesertTaco
    I rotated mine every 5k until 15k miles. Now with 18k miles, two of the four tires plugged, suspension parts waiting to be installed and new tires/wheels coming I refuse to rotate the factory crap any longer. :D OEM tires are practically junk after 18k miles anyway.
    Steves104x4 likes this.
  2. Feb 9, 2023 at 11:30 AM
    #62
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    So is everything else
  3. Feb 9, 2023 at 11:41 AM
    #63
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    Bring back the 5 tire rotation! i mean if i had a 5th nice wheel id 100% do 5 tire rotations.
    stickyTaco likes this.
  4. Feb 9, 2023 at 11:45 AM
    #64
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    That's what I do whenever I pull off 2 of them.
  5. Feb 9, 2023 at 12:14 PM
    #65
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Classic TW.
    Take something simple, and make it overly complicated.
    hooliganrick, Mully and Steves104x4 like this.
  6. Feb 9, 2023 at 12:30 PM
    #66
    cgolf
    cgolf Well-Known Member
    2020 Tacoma TRD Off Road
    None
    I went back to square tires. It eliminated all possible rotations issues!! :)
    Mully likes this.
  7. Feb 9, 2023 at 12:43 PM
    #67
    22MGMTaco
    22MGMTaco Well-Known Member
    Siberia of Texas
    Multiple MPG-killing pieces of armor and other stuff
    I'm not sure that the spare tire was factored in to OP's math.
    I did a few calculations for everyone's benefit and took the spare tire into account.
    Where:
    • alpha = rim size (in inches)
    • L = age of air in tires (in miliseconds)
    • delta = compression of cylinder # 3 (in stone per square decimeter)
    I won't insult the reader's intelligence by defining the remaining variables in the equation.
    As should be obvious from the above, the rotation interval (including the spare) should be once every 4812 hours, 22 minutes, and 3 seconds - with a deviance not to exceed 0.05 seconds.
    And, none of this front-to-back or side-to-side crap. The decision as to where each individual tire should be moved is to be made via a random number generator.
    There are times when a given tire will not be moved from its position during a rotation cycle. Chaos theory is your friend.
    Edit: Forgot to add that this is for the TRD Pro only.
    For all other Tacomas, it's every 10,000 miles.
  8. Feb 9, 2023 at 12:59 PM
    #68
    amyracecar
    amyracecar suck it up buttercup
    Virginia Applejack
    SouthEast USA
    2013 AC V6 MT OR Spruce/Mica
    So this is still going eah - - here is my 2cents
    I rotate the truck tires every 5K - Discount Tire does this for free b/c I got the tires there.
    I supervise so nothing stupid happens like not torquing the lug nuts or trying to torque them while it is still in the air . . .been there/done that nonsense, learned my lesson about auto techs..
    Tires are wearing nice and evenly
    My car has a staggered set up so no rotation there = easy
    I burn 2x rears to 1x fronts
    I kill the rears in about 12K miles = a good warranty discount on the new tires b/c Continental has a 25K mile warranty [actually 50K but on a staggered gotta divide it in half] on the tires so they pro/rate the replacement pair
    I used to think tire warranties were hog wash - however this situation has worked out well for me
    I can see where OP was going on the thought process - the best thing you can do is know your driving habits/patterns, how they affect the tire wear and rotate accordingly; also keep an eye out for uneven wear as that usually indicates something else may be amiss..
  9. Feb 9, 2023 at 1:15 PM
    #69
    TnShooter
    Deogee
    STOCK
    Your math is wrong.
    I know this because I don’t understand it.
    Isn’t that how this works now? If you don’t understand it’s “wrong”.
    You guys didn’t even account for air pressure. :rofl:
    Get out of here with your maths…..:D
    seedy_tea and Steves104x4 like this.
  10. Feb 9, 2023 at 1:21 PM
    #70
    22MGMTaco
    Siberia of Texas
    I beg your pardon? My math is impeccable.
    And, lest someone bring up the fact that there are 2 variables in the equation that are time-dependent (age of air in tires and compression of cylinder #3)....
    Using the units of stone per decimeter and of milliseconds leads to an inverse correlation between air age and compression. As air age goes up, compression goes down by the same amount.
    Duh! :crazy:
    Mully and TnShooter[QUOTED] like this.
  11. Feb 9, 2023 at 2:06 PM
    #71
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Since this turned into a cluster f…, how often should I change my oil again?:annoyed::annoyed::annoyed:
    Steves104x4 and Mully like this.
  12. Feb 9, 2023 at 2:10 PM
    #72
    TnShooter
    Deogee
    STOCK
    Every once in awhile is sufficient enough.
    Mully and gotoman1969[QUOTED] like this.
  13. Feb 9, 2023 at 2:22 PM
    #73
    Mully
    CA
    Never, just add to it when needed.
    Look how much money you just saved.
  14. Feb 9, 2023 at 3:56 PM
    #74
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I rotate mine winter to summer (8 tires) have no earthly ideal where they came from and frankly don't care have never seen any difference in the ware pattern.
    Mully likes this.
  15. Feb 9, 2023 at 6:41 PM
    #75
    6 gearT444E
    Deep South
    Herculiner Hootus
    malware can appear if not careful to screen your inbox.
    winkel and Reggie4x4 like this.
  16. Feb 9, 2023 at 6:44 PM
    #76
    TnShooter
    Deogee
    STOCK
    So what you’re saying is, it’s dependent on the Earth rotation around the sun.
    Makes perfect sense.
    buckhuntin-tacoma likes this.
  17. Feb 9, 2023 at 6:46 PM
    #77
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    You could always just get an alignment once
  18. Feb 9, 2023 at 7:03 PM
    #78
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    I buy new tires every 5k miles, no rotation needed, problem solved!
    Mully and TnShooter like this.
  19. Feb 10, 2023 at 4:46 AM
    #79
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    More like the cycles of the moon.
    TnShooter[QUOTED] likes this.
  20. Feb 10, 2023 at 6:54 AM
    #80
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    I usually eat my rear tires halfway down before the fronts get halfway. when it gets to this point, i just swap the fronts and the rears. after another 25k, they are worn evenly and its about time for new tires.
    you are overthinking this (unless you have an alignment issue)
    each vehicle will have front/back wear differences. my camry is the opposite of my truck, the fronts get worn first, but it's the same procedure. and then end up even at about the mileage that it is time for new tires.
